Old 02-20-2020, 03:34 PM   #5
tubman
tubman's Avatar
Default Re: how to remove coil 1941 merc
Originally Posted by rockfla View Post
On no V8 coil does the condenser help hold the coil on! So your condenser should come off with the coil. As I mentioned, being yours in "cracked" "most likely" is causing it to be "extra" tight fitting. Gently bump it on the sides, from the front, back and forth and it should pop loose!!
I don't know about this statement; your're gonna break something unless you remove the distributor mounting bolt the condenser strap is mounted under. The condenser has to be connected to the coil and to ground.
