Old 02-13-2020, 04:47 PM   #1
Derby
Default 37 fuel tank
The fuel tank outlet tube on my '37 is damaged and needs to be replaced. The retaining nut fitting has been rounded off and will not accept a wrench. Prior to my attempts to loosen the fitting, I am asking for help in understanding the connection. The tube must extend about three inches through the fitting into the tank. Is the fitting soldered in place or is it removable? I want to avoid more damage in the attempt to remove the fitting.
Derby is offline   Reply With Quote
Old 02-13-2020, 04:58 PM   #2
mrtexas
mrtexas's Avatar
Default Re: 37 fuel tank
I would fill tank up with water and then apply heat to the tank fitting. Line should then come out easily.
41 woodie https://41fordwoodie.weebly.com/
mrtexas is offline   Reply With Quote
Old 02-13-2020, 05:19 PM   #3
Kube
Kube's Avatar
Only apply enough heat (after filling tank with water) to get that fitting moving. You don't want to disturb the seal between the boss and tank.
The tube goes in the tank about 3/4" at most.
Old 02-13-2020, 06:01 PM   #4
jimTN
You also could drill out the tube even with the nut, drill a couple of small holes thru the nut on opposite sides and use a easy out.
Old 02-13-2020, 06:13 PM   #5
Flathead
Flathead's Avatar
Tap a six point socket onto it, use metric if you need a tighter fit.
Flathead is offline   Reply With Quote
Old 02-13-2020, 07:14 PM   #6
Derby
OK, great responses. I will proceed cautiously. While doing some previous tank work on a different car someone suggested putting some dry ice in the tank. The dry ice sublimates and releases CO2 that displaces all gas vapors with a little patience.
Old 02-13-2020, 08:14 PM   #7
Kube
Kube's Avatar
Derby, I too had heard of the dry ice thing. Water is easier and cheaper
Old 02-13-2020, 08:57 PM   #8
fourfords
fourfords's Avatar
Any problem with using a penetrant and a small pipe wrench to remove an already unusable and damaged fitting?
fourfords is offline   Reply With Quote
Old 02-14-2020, 10:57 AM   #9
V8COOPMAN
V8COOPMAN's Avatar
Only problem with filling the tank with water is that the water becomes a GI-HUGIC heat sink. You ever try melting solder on a copper fitting with the copper pipe still full of water? Almost impossible! Might consider purging the tank with a CO2 fire extinguisher. DD
Click Links Below __
T5 W/TORQUE TUBE
Old 02-14-2020, 11:45 AM   #10
marko39
Vise grips.
marko39 is offline   Reply With Quote
Old 02-14-2020, 12:34 PM   #11
Terry,OH
Terry,OH's Avatar
ditto the vice grips and penetrating oil. The tube goes in just a little bit.
Old 02-18-2020, 04:03 PM   #12
hook00pad
I agree on using vice grips, but be careful not to crush your fitting!
Al Hook
hook00pad is offline   Reply With Quote
