01-28-2020, 07:28 PM | #1 |
Dipstick for Tremec T170 Transmission
The previous owner of my 1931 Victoria replaced the original transmission with a Tremec T170 (an overdrive transmission).
Does anyone know if Bratton's "Transmission Dipstick Set Up" (https://www.brattons.com/transmission-dipstick-kit.html) will thread into the fluid check hole and work without modification? Or, does the Bratton work with some sort of modification? Or, is this not even an option for a T170? |
01-28-2020, 10:30 PM | #2 |
Re: Dipstick for Tremec T170 Transmission
Maybe it would be best to contact a Tremec dealer. I spoke to a dealer from Texas at the Good Guys Car Show at Del Mar last year.
By the way, I’m interested in finding out how the transmission is working out for you. David Serrano |
01-29-2020, 05:30 AM | #3 |
That’s the problem. It has been difficult to learn much about this transmission. I don’t know where to find a Tremec dealer. I had it to an area transmission shop (where I’ve taken antique cars in the past), but they didn’t want to work on this one.
As I understand it, it’s out of a 1984 Ford Bronco. The day I bought the car, it shifted wonderfully. After I drove it home, it developed a really bad leak (1 oz every 11 miles) within about 600 or 700 miles and started shifting hard. I think the seller was honest, but the car had been sitting for a while in a garage. Sometimes old cars start leaking after they start on the road again. I finally found a Model A mechanic, and he replaced the rear seal in the transmission. I’ve driven it a couple hundred miles since then, and I’m cautiously optimistic that it is fixed. However, I still feel the need to climb under the car to check the fluid every time I drive it, which is a nuisance. So, I’m thinking a dipstick might be a better way to check the transmission. Sent from my iPhone using Tapatalk |
01-29-2020, 06:42 AM | #4 |
shew01, the 3spd overdrive transmission in a model a is a custom conversion. I don't think there's a vendor that makes accessories for this setup.
I installed this same transmission in my 30 coupe, and the difference from the original non synchro 3spd to the RTS (T170) is night and day. You replaced the rear bearing with a sealed one, so you should be all set. If you were leaking 90 weight trans oil, you'd notice it leaking from the clam shell. It would be thicker than motor oil. I'd check it regularly from the plug, and if the level isn't dropping it should be good. If you want to know more about this transmission do a search here and you'll learn more than anywhere else. John |
01-29-2020, 08:05 AM | #5 |
I just checked mine the other week and the fill plug is the same threads and size and about the same location as the Model A fill plug.
01-29-2020, 01:57 PM | #6 |
The model A transmission will easily accept a dip stick and I know there are kits for them but I don't know about any for the T170 RTS unless it's stated that it's for that model. It just depends on whether there is anything in the way inside there. With all the synchros and the cross over rocker set up in there for the ovrdrive, it's pretty busy inside that housing. I don't know if they have much for a drain plug either unless the tail housing is removed. It seams like a person has to draw it out of there with a lube suction gun. If a suction gun will go in then the dip stick could. Last edited by rotorwrench; 01-29-2020 at 02:25 PM. |
01-29-2020, 02:32 PM | #7 |
Location: Daniel Island,SouthCarolina/Knoxville, Tennessee/Sanibel Island,Florida
No drain plug on these as I understand.
01-29-2020, 06:58 PM | #8 |
No pictures to help so lots of description. I climbed under my cars to measure and see how this new dipstick thingee will fit and work.
On my car wiht stock model a transmission the new dipstick thingee willcome thru the floorboard about 3.5 to 4 inches behind the emergency lever and about 1 inch to the right - plenty of room. on the F150 transmission it will come up thru the floorboard about 2.5 to 3 inches behind the emergency lever and about 1 inch to the right -again plenty of room. The threads in hte stock Model A fill plug are 1/2" pipe plug. The threads in the F150 fill plug are the same thing - 1/2" pipe thread. Thus the new Brattons dipstick thingee will fit into and up thru the floor of your Model A. My opinion. Once you have the sealed rear bearing into the back of the F150 transmission you wont have to worry about leakage again. Nor will you have to check the level every 1000 miles - unless sumpin else goes wrong. Refeence. My F150 in my coupe has over 30,000 miles on it and the level is still up to the top of the threads of the fill plug. These RTS transmissions out of the 1985 thru 1987 F150 have no drain plug. ken |
02-01-2020, 12:42 PM | #9 |
Listen to Ken, he used to sell F150 install kits for the Model A. The full level mark on the dipstick will read correctly on the F150 because both the F150 and the Model A transmission are full when the oil runs out the fill hole,
AL in NY |
02-08-2020, 09:04 AM | #10 |
I purchased the dipstick from Snyder’s. Unfortunately, it does not fit.
02-08-2020, 09:16 AM | #11 |
does someone have the part number for the sealed rear bearing for the T170?
02-08-2020, 09:19 AM | #12 |
Ken Parker would likely have it. Ken, would you mind posting the part number?
02-08-2020, 09:47 AM | #13 |
Think the issue is the dip stick pipe is 3/4 pipe thread and the trans plug thread is 1/2 pipe. Maybe you can get a pipe nipple with 1/2 pipe threads of the correct length, modify a pipe cap and use the dip stick. The mod really is worthwhile and simplifies checking and adding lube. The system is actually designed to slowly pass oil through the aft bearing to lube the U joint which means checking and adding oil is actually routine maintenance.
02-08-2020, 10:20 AM | #14 |
02-08-2020, 02:45 PM | #15 |
The part number for the one sided sealed rear bearing I used was MRC308SZZG, but I don't remember the manufacturer.
AL in NY |
02-08-2020, 07:19 PM | #16 |
It has an MRC number. SKF is the parent company for MRC now days.
02-08-2020, 08:12 PM | #17 |
Al is right. The part number is 308SZZG. Manufacturer is MRC. Dont know about the parent company thing. Roto is probably right. The ZZ stands for the seal on both sides.
02-08-2020, 09:47 PM | #18 |
For the SKF bearing series used on the Tremec Ford overdrive transmissions, you need a 6308 2RSNR bearing. This bearing has an inner and an outer rubber seal, thus the 2RS designation and the necessary snap ring, NR designation for retaining ring, on the outer race. You can remove the unnecessary inner seal if desired. A ZZ bearing has two metal shields, one on each side and may be more leak prone when used for the tailshaft bearing. You must use the bearing with the outer race retaining ring in the F150 OD transmission.
02-09-2020, 03:45 PM | #19 | |
