Old 01-22-2020, 10:01 PM   #1
Vanspeed
Vanspeed's Avatar
Default My ‘29 V-8
Been converting my beloved 1929 coupe to V-8 power this winter. The 4 developed a noise after 10 good years of driving and I had this 1936 LB Flathead so I decided to do the swap. I have not modified the body in any way, no cutting of the firewall, using only original Ford parts. I have had a ‘39 V-8 trans behind the 4 for the last 9 years so nothing drivetrain wise needed to be cut or anything. Concept is as if a kid bought a new wrecked 1935 ford and swapped everything over a Model A.
Respecting and Resurrecting Ford Model A's.
Vanspeed is offline   Reply With Quote
Old 01-22-2020, 10:04 PM   #2
Tim Ayers
Default Re: My ‘29 V-8
Very cool!
Old 01-22-2020, 11:26 PM   #3
Bored&Stroked
Bored&Stroked's Avatar
Betcha can't wait to go down the road with the new engine! Looks like a nicely done car - have some fun!
Old 01-23-2020, 12:34 AM   #4
Russ/40
Russ/40's Avatar
I'd be interested in hearing more about how you tackled the problems along the way. Exhaust, engine mounts, radiator to firewall space, steering box, fan, etc, etc.
Old 01-23-2020, 04:58 AM   #5
Brian
Brian's Avatar
Excellent upgrade!!
Old 01-23-2020, 07:40 AM   #6
mfirth
Absolutly love it ! All FORD too!
mfirth is offline   Reply With Quote
Old 01-23-2020, 07:57 AM   #7
corvette8n
corvette8n's Avatar
Looking good, keep the pics coming.
Old 01-23-2020, 08:08 AM   #8
Charlie ny
Keep us updated by all means...some guys fantasize about what you are doing...you're
living it....brakes ?
Charlie ny
Old 01-23-2020, 09:40 AM   #9
rotorwrench
rotorwrench's Avatar
The 32 Ford and Bonus Built F1 cross members have been used to beef up the frame. What did you use on your AV8? I can't quite tell from the photos.
Old 01-23-2020, 01:30 PM   #10
Vanspeed
Vanspeed's Avatar
32 wishbone. Handmade trans crossmember.
Old 01-23-2020, 02:52 PM   #11
Step-down
Step-down's Avatar
Nice looking job .
"I can't cry as long as I know the Lord has risen "
Step-down is offline   Reply With Quote
Old 01-23-2020, 06:22 PM   #12
5851a
The reason I quit subscribing to Street Rodder, Hot Rod, etc. is they stopped showing builds like yours. Looks great, day dreamed a lot about a AV8 in elementary school. Looks nice.
5851a is offline   Reply With Quote
Old 01-23-2020, 09:12 PM   #13
Vanspeed
Vanspeed's Avatar
Thanks guys! I have a lot of pictures so I will post as many as I can. This car has not had one piece of sheetmetal cut. ‘36 engine. ‘39 trans. ‘29 A stock rear end. Stock pedals. Lots of fab work to make it all look like nothing was changed.
Old 01-24-2020, 09:18 AM   #14
ct1932ford
ct1932ford's Avatar
Looks Great!
A man should do what he thinks best! "The Duke"
ct1932ford is offline   Reply With Quote
Old 01-24-2020, 09:30 AM   #15
chiefdave
chiefdave's Avatar
Looks like it is going to be a very nice and period correct build. Any plans to warm up the engine with period correct parts?
chiefdave is offline   Reply With Quote
Old 01-24-2020, 08:47 PM   #16
TomT/Williamsburg
TomT/Williamsburg's Avatar
Looks good!
TomT/Williamsburg is offline   Reply With Quote
Old 01-24-2020, 10:51 PM   #17
Vanspeed
Vanspeed's Avatar
Yes down the road I would like to do that. Just doing the swap is eating up my budget. I bought a new stromberg 97, a rebuilt crab distributor from bubba, rebuilt ‘36 generator and the radiator changes are up more than $1400! The early speed heads are hard to find and expensive.
Old 01-24-2020, 10:59 PM   #18
Vanspeed
Vanspeed's Avatar
More pics. Have a set of single grove waterpumps and this set of double groove. Mechanical fan is the last thing I need to fab/make and it is proving a little difficult. Stock gen mounted fan is too high, 40 style is too low. Need a clever way to put it in the middle of the radiator and make it look factory but I have not come up with it just yet.
Old 01-25-2020, 01:29 PM   #19
V8COOPMAN
V8COOPMAN's Avatar
Below is a link to a mechanical fan project that FordBarner Heard and myself came-up with to solve a space problem on his '36 3-window with an 8BA engine. The radiator leans rearward on a '36 and the upper gen mount was too high. We needed something about MID-Engine in height. We designed and built this assembly that mounts to the intake manifold generator mount. Works really well to cool his engine in the Florida heat. If you think something similar MIGHT work in your situation, I'll be happy to elaborate and show more pictures. You would POSSIBLY need to convert to an 8BA-type distributor for clearance. Click the link and read Post #12. DD
https://www.fordbarn.com/forum/showt...mechanical+fan
Click Links Below __
T5 W/TORQUE TUBE
Old 01-25-2020, 01:54 PM   #20
john in illinois
john in illinois's Avatar
Is the fan too high on the generator because of radiator hoses? You can lower the front mounts or trim the fan blades shorter.
My fan is close, but it is a stock ‘39.
Mine is a ‘30 ,so the radiator may be taller.
File Type: jpg 9AB972C3-C2DD-414A-840A-62A7F3053344.jpg (82.8 KB, 221 views)
Welcome each day
john in illinois is offline   Reply With Quote
