Old 01-18-2020, 12:32 PM   #1
Dennisfly
Dennisfly's Avatar
Default Steering Column Bracket
I have the standard steering column gas tank bracket on my 1929 Fordor Town Sedan. I want to replace it with the 1931 style that mounts on the dash rim to lessen the chance of a fuel tank leak. None of the suppliers stock them anymore but a local club member was nice enough to give me one.
I looked at Tom Endy's pictures and instructions and it looked pretty straight forward. The problem is his pictures (the first and second ones) shows access to the back side (upper) of the dash rim to place a nut on the bolts of the adapter piece. My picture (the third one) shows no room to do this. I removed the dash wind deflector and the windshield molding but still no access.
Anyone know how to get around this?
1929 Town Sedan (Briggs) 155B, Mitchell Overdrive
1935 Model 48 Tudor
Dennisfly is offline   Reply With Quote
Old 01-18-2020, 12:42 PM   #2
Dennisfly
Dennisfly's Avatar
Default Re: Steering Column Bracket
I did some looking and may have answered my own question.
1/4" U nut at Home Depot $.75
File Type: jpg metallics-everbilt-composite-fasteners-800078-64_1000.jpg (22.5 KB, 13 views)
1935 Model 48 Tudor
Old 01-18-2020, 05:22 PM   #3
David R.
Why does no one have these anymore? I have been looking for one also. I would like to find an old original off the gas tank and I would make one, welded up.
David R. is offline   Reply With Quote
Old 01-18-2020, 05:48 PM   #4
Steve Plucker
Go to VFF for your answers.
Pluck
Old 01-18-2020, 06:11 PM   #5
Synchro909
Synchro909's Avatar
Here's an opening for some enterprising fellow. If you can lay your hands on one, make a pattern and cast them yourself. No Model As were imported here in 1931 so we didn't see that bracket. Any that might be about now are going to be from an imported car. No one ever reproduced these brackets for a RHD car as far as I can see so when the tank started to leak on my car, I bought a LHD one to see what they were like and cut it up as the basis of a pattern for a RHD version. I cast them in aluminium and heat treat them for '28 and 9 cars and it takes only a minor alteration to make one fit the later cars. There are not all that many 1930 cars here either by comparison to the early ones.
Maybe you could do similar - maybe a club project?
When all is said and done, more is said than done. That's why we judge people on what they do, not what they say.
If I am not in trouble, I've done something wrong.
Old 01-18-2020, 06:14 PM   #6
Tom Endy
Tom Endy's Avatar
The attached article may be of help. If you are installing a bracket that attches to the dash rail on a 30-31 car it will bolt right up. If you are installing it on a 28-29 car you have to make an adapter bracket.
Tom Endy
http://www.santaanitaas.org/wp-conte...lumn-Mount.pdf
Old 01-18-2020, 07:38 PM   #7
Dennisfly
Dennisfly's Avatar
Thanks Tom. I'm prepared to make the adapter. It's the ability to get the nuts behind the panel for the attaching bolts that concern me. Hopefully the "U" nuts will facilitate that.
1935 Model 48 Tudor
Old 01-18-2020, 08:36 PM   #8
The Master Cylinder
The Master Cylinder's Avatar
Am I missing something. Snyder's still lists The steering column bracket.
https://www.snydersantiqueauto.com/P...earchByKeyword
The Master Cylinder
Enjoying life at the beach in SoCal...
The Master Cylinder is online now   Reply With Quote
Old 01-18-2020, 09:27 PM   #9
Benson
holes in the bar.
Old 01-18-2020, 09:33 PM   #10
David R.
They all list them, but when you order they say they are out of stock.
Old 01-18-2020, 09:37 PM   #11
David R.
Excuse my ignorance: what is VFF?
Old 01-18-2020, 10:51 PM   #12
Steve Plucker
Sent you a PM (Personal Message)
Old 01-19-2020, 01:21 AM   #13
The Master Cylinder
Ah, I see. I see them on ebay quite often. https://www.ebay.com/itm/MODEL-A-FOR...IAAOSwc7teHlMF
Bert's more than likely has some used ones also.
The Master Cylinder
Old 01-19-2020, 11:30 AM   #14
klawockvet
klawockvet's Avatar
I did not like the looks of a 31 column drop on my 28. I took a 1/4 x 2" flat bar and ran it from flange to flange on the cowl. It is bolted to the cowl on each side as well a single bolt into the instrument tunnel. I used a 36 column drop with the key an toggle as mine is a hot rod but this same thing can be used with an additional functional column drop supporting the column independent of the stock drop.
klawockvet is offline   Reply With Quote
Old 01-19-2020, 12:22 PM   #15
quickchange
quickchange's Avatar
We produce the new right hand drive ones, also have the odd original LHD one , see them on flea bay & at usa swap meets , [email protected] Have a couple spare RHD 2 tooth steering boxes available too, Derek from a hot dry New Zealand,
quickchange is offline   Reply With Quote
Old 02-07-2020, 11:45 AM   #16
Dennisfly
Dennisfly's Avatar
1/4-20 Panel Range .064"-.125" Center 9/16" U Type Nut from Fastenal fixed the problem. The spring/U nuts from Lowes/Homedepot/local hardware store were not deep enough. My car was different from other 28/29s in our local club. Tudor Sedan, and Coupe had room to use a normal nut.
1935 Model 48 Tudor
Old 02-07-2020, 11:49 AM   #17
ryanheacox
ryanheacox's Avatar
That makes sense since the Fordors used a different cowl.
Old 02-07-2020, 04:22 PM   #18
PalAl
PalAl's Avatar
Did you happen to take pictures of what you did? I have a 29 Fordor Briggs and was stumped as to changing the support. Put it off for a later date. Would like some info on how you did the new support if you would like to share. Thanks
PalAl is offline   Reply With Quote
Old 02-08-2020, 10:04 AM   #19
Dennisfly
Dennisfly's Avatar
I bought a piece of Aluminum 3/8 X 1 X 8 on Ebay. I used a grinder and file to shape the top to the contour of the tank/panel where it would be attached. I carefully measured and drilled four holes to accommodate 1/4 inch machine screws. Two to attach this piece with screws going up into the panel and two to attach the bracket with screws going down. The holes were countersunk and flat head screws used. I'll see if I can take a picture or two. The link in post #6 actually has great pictures and description by Tom Endy. The only difference with mine is the use of the Fastenal U nuts due to the restricted access.
Last picture shows old mount with column placed so it doesn't touch the tank area.
1935 Model 48 Tudor
Old 02-08-2020, 11:17 PM   #20
PalAl
PalAl's Avatar
Thank you I didn't understand the placement of the U nut....
This old guy gets it, easy. Much better then hanging on the tank
