Old 01-17-2020, 09:18 PM   #1
James G.
Default Head light focusing procedure
I'm finally convinced that my night time driving issue with my Tudor headlight must be focusing. I've cleaned the reflectors, checked the headlamp bulbs, all in excellent shape. Where can I find/get a copy of this steps/procedure? Any/all help greatly appreciated! Jim Gregory, GBMAFC
James G. is offline   Reply With Quote
Old 01-17-2020, 09:26 PM   #2
Gary WA
Gary WA's Avatar
Default Re: Head light focusing procedure
Model A Ford Mechanics Handbook Vol1 by Les Andrews sold on MAFCA or Model A Vendors Berts,Brattons etc.
www.whidbeymodelaclub.com
Old 01-17-2020, 09:29 PM   #3
Gary WA
Gary WA's Avatar
may help?
Old 01-17-2020, 10:16 PM   #4
Ranchero50
Ultimately take the car out to a dark section of abandoned road and adjust them there so you can see stop signs and the road in front of you. I do it at industrial areas.
Building a '29 Speedster, the hard way...
Ranchero50 is offline   Reply With Quote
Old 01-17-2020, 10:20 PM   #5
Dennisfly
Dennisfly's Avatar
I believe it is also in the Model A instruction Book
1929 Town Sedan (Briggs) 155B, Mitchell Overdrive
1935 Model 48 Tudor
Dennisfly is offline   Reply With Quote
Old 01-17-2020, 10:44 PM   #6
GMCPASO
GMCPASO's Avatar
It helps if it is a foggy night also.
GMCPASO is offline   Reply With Quote
Old 01-17-2020, 11:04 PM   #7
ryanheacox
ryanheacox's Avatar
I don't think anyone has asked what reflectors you have? If they are the chromed ones then you may not be able to properly focus the bulbs no matter what you do.
Old 01-18-2020, 12:58 AM   #8
Kurt in NJ
Kurt in NJ's Avatar
If you take the lens off, shine the light on a wall 25 feet away the property focused beam without the lens will look like this
Old 01-18-2020, 10:32 AM   #9
Badpuppy
Originally Posted by Gary WA View Post
may help?
The pics are from the Model A instruction book (owner's manual). Beam height is 33" for 28-29, 37" for 30-31 to agree with headlight center height.
Old 01-18-2020, 10:52 AM   #10
captndan
captndan's Avatar
Just loosen the nut on the bottom and point the lights wherever you want.
captndan is offline   Reply With Quote
Old 01-18-2020, 12:24 PM   #11
Bob C
That will work for aiming the beam but it won't do anything for the focus.
Bob C is online now   Reply With Quote
Old 01-18-2020, 01:43 PM   #12
Will N
Will N's Avatar
Ditto. The repros that were available were not the correct shape and you will never be able to focus them. Bratton's sells a new coated aluminized reflector that is made to the original blueprint, and these can be focused. Of course, so can originals where the silver is in good condition.
Will N is offline   Reply With Quote
Old 01-20-2020, 09:09 AM   #13
29closedcabguy
29closedcabguy's Avatar
I was not able to focus my headlights or get as much light out of them as I felt they should produce. I tried everything even led bulbs. Finally I discovered I had the poorly designed crome reflectors. I installed the new aluminum reflectors and BOOM!!!! I now had actually high and low beam not just brighter on high beam. Also the original silver reflectors reflect 95% of the light, chrome reflectivity is only around 65%. The new polished aluminum is 90% reflective. I went from none focused 65% reflectivity to 90% focused lighting. The resulting outcome was like magic.
29closedcabguy is offline   Reply With Quote
Old 01-20-2020, 09:20 AM   #14
ryanheacox
ryanheacox's Avatar
Great! I was in the same boat as you, bought new Brattons reflectors and was blown away by the difference.
Old 01-20-2020, 10:26 AM   #15
Ranchero50
That was the problem I found with LED's. The light emitter wasn't at the same spot as the Halogens so the focus was way off.
Old 01-20-2020, 11:36 AM   #16
Steve Rinaldo
How do you tell if you have silvered, chrome or aluminum reflectors? Thanks, Steve
Steve Rinaldo is offline   Reply With Quote
