Old 01-02-2020, 08:00 PM   #5
Bored&Stroked
Bored&Stroked's Avatar
Default Re: crab distributor setup
Originally Posted by tubman View Post
I bought an old dwell/tach of eBay a couple of years ago for $20 plus shipping. I used it to set the dwell on the Mallory dual point in my '51. It was mainly trial and error (tweak the points and re-check), but it didn't take long to get it where I wanted it. I would imagine it would work the same way on a pre-8BA except it's a little more difficult to work on because of the location of the distributor.
The current meters that use 12 volt power won't work in a 6 volt car; you need the kind that doesn't require external power.
Hmmmmmm . . . wondering if you can do the same thing I've done with a timing light. Could you connect the negative side of the 12V battery to the frame and them the positive side to the dwell meter . . . while at the same time you're still running the 6V system? Just pondering out loud . . . as I'm away from my equipment on vacation in the Black Hills of SD.
Happy 2020 Gang!
B&S
