Ok Gents, I need some help
![]() Been fighting an issue w/my 1936 21 stud flathead since late summer; I took my car for a test run in early Sept for about a mile and it left me stranded from what I thought was a bad gas/trash related issue, while driving about 6 blocks from my house it started to stumble and back fire and slowly died. Had to tow her home. ![]() Since then I have changed:
Video below; https://youtu.be/XGnfJEmKcsE (background noise in video is shop fan)
Regards, Todd 1936 FORD Tudor Slantback "cajunhotrodder" on instagram/youtube Last edited by cajunfirehawk; 01-20-2020 at 12:58 AM. |
Stick a vacuum gauge on it and see what it's saying . I'd check to see the exhaust is clear and no blockage . The vacuum gauge will go down steadily till it stalls . Of course other things will give like readings .
How soon after it dies can you restart it ? Orig or rebuilt coil ? 6 or 12 volt Sorry didn't get the video to run on the service I'm using |
Condenser....I know, you've changed it....change it again
If it were mine, I'd fire it up and while idling I'd pull the coil wire out of the coil 'til I could see the spark jumping...should jump at least 3/8" and be blue and "snap" audibly. You won't get shocked because you'll be holding the dist side of the wire.
If spark is good, I'd play with the choke to see if it helps/hurts the way it runs. Next I'd look in the distributor to see if maybe the spark is jumping through the rotor to the shaft. It happens sometimes. That can be hard to check because you can't do it running. A different rotor helps rule that out. And oh...the adapter on the dist for the external coil? The spring that contacts the points strap can bend and barely touch ground. That one got me once... And yes, don't trust a condenser even if it's new. Terry
"It don't take but country smarts to solve the problem" (Smokey Yunick) '30 Model A Speedster '41 Merc Town Sedan / 260" 8CM engine '66 Fairlane four door / "warmed up" 302
Look in the service bulletins ,they show how to make a high tension checking tool ,so you can check all the HT parts in the dist.
all you need is a Model T coil and a battery. Lawrie |
As Brian says, replace the condenser again. You could fit it up on the coil for ease of replacement. Remove the original one off the dist plate. I don't like the way your coil is vibrating, not good for it so fix its mounting bracket. Regards, Kevin.
From the video what I'm getting:
*12volt Bosche coil, so it's 12volt (i'm guessing). *Conversion dizzy coil cap, so still running duel points. *Those red plug wires, guessing they are not spiral carbon, but solid copper core. (solid core for points) *Fuel pressure around 2-4, that is good. *Vacuum around 15", 15" is too low for a engine, it should read a fairly steady 19" and when you step on it, it will drop to around 3-5" (not 0"). Adjust the idle and air screws on the carb to get it to around 19". That will help first off. (It bounces a little but that should improve as it runs more (valves maybe a little sticky)). The hot engine shutdown... as mentioned, try another condenser (out of the box new is not always great). Also may want to pull some plugs and see what they look/smell like after it quits. good luck! Last edited by Tinker; 12-30-2019 at 02:38 PM. |
Is the wire from the coil to the dist fully seated in the coil??
Paul in CT |
#10 | ||||
Thanks for all of the feedback, some answers below...(in bold)
Once again, I thank each and every one of you for your input, I am determined not to let this car beat me, so 2020 IS the year it runs again! Also, will try and get a better video without the back ground fan noise now that winter has returned once again (for the next few days anyway) HAPPY NEW YEAR
Regards, Todd 1936 FORD Tudor Slantback "cajunhotrodder" on instagram/youtube |
Are you still using the resister between the switch and the coil?
Bruce
Works good Lasts long time |
No, went with a coil w/internal resistor on the advice of Bubba's ignition and some others too...
#13 |
I have written this before but if you are running a modern can type coil on a helmet distributor, especially 12 volts you are creating a pretty hot spark from the coil. If you look at the rotor for the helmet type distributors, the place where the carbon runs on it in the middle is directly above the steel shaft that rotates it. I suspect the high tension spark coming from the coil is jumping THROUGH the rotor to the shaft. Many folks put a shrink wrap layer on the shaft to help prevent this. The stock coils didn't produce as much high tension voltage as the modern 12v coils. Sometimes you can get away with it but I know of more then 1 person who has had this problem due to the construction of the rotor wasn't designed for what you are doing and electricity will go to the easiest ground always, and sometimes it is right down through the rotor. Try a different rotor. I hope your press on timing gear hasn't moved, that would be a big problem to fix.
Hope you find the gremlin. Last edited by deuce_roadster; 01-01-2020 at 01:24 PM. |
#14 | |
#15 |
I know my comment to this tread is going to sound crazy to some people, I am going to make the comment anyway.
Over fifty years ago I had a friend that had a very nice '36 Ford 2 dr sdn, the car was a custom car of the era. The Ford developed an intermediate problem which caused it to stall and then quit running. The issue was driving my friend nuts. After many attempts to correct the problem to no avail the fuel tank was removed. The tank was found to contain a few common green grapes. The grapes would roll around the bottom of the tank when one came in contact with the fuel pickup, the vacuum would pull the grape to the pickup tube shutting the fuel flow off, once the engine stopped the vacuum was broken and the grape rolled away. A second option for the problem could be as simple as an un-vented fuel cap. I ran into this problem in a road side rest in Idaho one snowy fall day. A lady pulled into the road side rest in a '56 Chevy pickup that died on the spot. The lady asked me if there was a phone near by, I told her she could use my cell phone. I asked the lady what was the problem, telling her that I might be able to help. The lady told me that the truck had been in and out of the shop many times during the past several weeks. On every occasion the truck would quit running within a short period of leaving the shop. I opened the hood, there sat a nice new SBC, looking around I noted the HEI ignition and noted the ignition was hooked to the original ballast resistor on the fire wall.. Not a good thing, I switched one wire over to the incoming 12v post. I then looked things over, noted a nice new chrome fuel cap, removed cap and noted it was un-vented. I cut the bottom out of a empty soda pop can and placed it over the fill neck to keep the snow/water out. Truck started right up. The lady thanked me and drove away. Several minutes later the lady returned in the truck, told me it was running fine and she was heading home. The rest of the story: The lady infomed me she was a certified mechanic at a local GM dealership, she had no idea what that gizmo on the firewall was and had never heard of vented/unvented fuel caps.
Bill.... 36 5 win cpe |
#16 | |
Awesome stories! The stalling issue started with an old rusty nissan junk yard fuel tank and fuel neck/cap, all of that was replaced with new correct to the car 36 fuel tank from Tanks Inc. w/vented cap. Still same issue. I do like grapes though
#17 |
*Vacuum around 15", 15" is too low for a engine, it should read a fairly steady 19" and when you step on it, it will drop to around 3-5" (not 0"). Adjust the idle and air screws on the carb to get it to around 19". That will help first off. (It bounces a little but that should improve as it runs more (valves maybe a little sticky).
If I adjust air/fuel screws out further it starts back firing thru muffler every so often, really want to think not getting enough voltage Checking ignition switch next! Condenser is Echlin FA54. Already did compression test and all cylinders had better than 80 lbs AND I also poured marvel mystery oil down each cylinder too plus added some to the fuel tank.Starting point is 1 and a 1/4 turns out on air/fuel mixer screws.You might need to adjust the idle screw also. Set the carb air/fuel screws to 1 and 1/4 turns, then adjust the idle screw to keep it running at a decent rpm.... Then fine tune the air/fuel screws to a vacuum gauge to 18-20". I'm not saying this will help the intermittent running, almost certain it won't, but should help fuel delivery, etc. |
#18 |
More pictures of the car!
#19 |
#20 |
cajunfirehawk, one of the hardest things for me to get used to is that NEW doesn't = GOOD anymore. When I grew up (I'm almost 70) and when you replaced parts with a new ones you could eliminate each as the problem. Not anymore. I'm sure all of us are hoping you find the gremlin and let us know what it was.
