12-21-2019, 04:31 PM | #1 |
8BA in 1937
I am in the process of installing an engine with an 8BA block. The steady rods need to be fitted to the block by drilling out the hole locations at the rear of the block. Attached is a picture taken by someone who has done the job. Possibly I found it on this Forum. I want to do it properly. Any advice will be appreciated.
12-21-2019, 04:56 PM | #2 |
Re: 8BA in 1937
Your photo didn't show up. Are you sure the photo file is the correct size to post? If you need help posting it let me know.
12-21-2019, 05:12 PM | #3 | |
Re: 8BA in 1937
A pair of adapter plates can be fabricated using the existing bell housing mount bolts. Or brackets may still be available from the vendor listed in the thread below. See here--------- https://www.fordbarn.com/forum/showt...t=chatter+rods
DON'T RECALL DOING SOMETHING FOR MYSELF BASED ON SOMEONE ELSE'S LIKES OR DISLIKES Last edited by 51 MERC-CT; 12-21-2019 at 05:18 PM. |
12-21-2019, 05:22 PM | #4 |
Re: 8BA in 1937
Don't drill the block.
There is a fellow that makes cast brackets for fitting chatter rods to an 8BA. Here it is: https://www.fordbarn.com/forum/showthread.php?t=226558 Take a look at all the postings this thread. I welded little ears the the stamped steel bellhosing and then made the rods longer in Post #8. Make sure rods clear brake and clutch pedals when depressed. https://www.fordbarn.com/forum/showt...ba+steady+rods Also shown in above thread is also an aftermarket anti chatter rod kit that was made. Bolts to transmission and hooks onto X member. I also installed that since I had it. Last edited by 19Fordy; 12-21-2019 at 05:37 PM. |
12-21-2019, 07:37 PM | #5 | |
Re: 8BA in 1937
Derby...What had you planned to do about a fan? 8BA-type fans don't lend themselves toward co-habitating very well with that rearward-leaning radiator in a '37. If you don't have something worked-out, I can show some pics of what we did to alleviate the same situation on a '36. DD |
12-21-2019, 07:47 PM | #6 |
Re: 8BA in 1937
12-21-2019, 07:58 PM | #7 |
Re: 8BA in 1937
Yes, any help with picture posting would be appreciated. appreciated. Picture is 750x586. I just used "choose" option and selected picture file
12-21-2019, 08:18 PM | #8 | |
Re: 8BA in 1937
Derby...I'm rounding-up some fan pics for ya. JSeery in post #2 above is quite generous and really good at helping folks post pictures. DD |
12-21-2019, 08:40 PM | #9 | |
Re: 8BA in 1937
Derby....For several pictures and the entire story on the project, click the link below and read post #12 in it's entirety. Picture below is just a teaser. I have several more pics and details if you decide to undertake such a project. DD https://www.fordbarn.com/forum/showt...mechanical+fan |
12-21-2019, 09:43 PM | #10 | |
Re: 8BA in 1937
12-22-2019, 10:52 AM | #11 |
Re: 8BA in 1937
Thank you for the fan info! In regard to the steady rods, I agree with the recommendation not to drill the block. The add on brackets are good, but I plan to use the existing threaded holes in the block with modified rods. If the approach is proves feasible, I will post some info. This forum is great.
12-22-2019, 11:08 AM | #12 |
Re: 8BA in 1937
Derby: V8 and I made our fan set ups before Bob Drake came out with his fan pulley. His product is very fairly priced. You could use his part as part of your set up.
https://www.bobdrake.com/SearchForm....0&searchtype=0 Last edited by 19Fordy; 12-22-2019 at 12:04 PM. |
12-22-2019, 11:25 AM | #13 |
Re: 8BA in 1937
I have been involved with two installations of 8BA style of engines in a '37 Ford, other than dealing with an adapter to attach the steady rods and the use of '49-50 Merc motor mount spacers, the whole deal was quite simple.
See attached pix.
Bill.... 36 5 win cpe |
12-22-2019, 12:50 PM | #14 | |
Re: 8BA in 1937
You continue to post this example when FordBarners ask for information or advice involving the swap of an 8BA into a '37 Ford passenger car. Your example is of an 8BA into a '37 PICK-UP TRUCK. That information is very misleading and confusing to a new-comer or neophyte engine swapper asking for reliable information. The '37 pick-up radiator sits essentially straight up and down and presents no interference with an 8BA fan. A '37 CAR radiator leans rearward and presents mucho interference with an 8BA fan. WE should ALL make an effort not to lend any more confusion to the folks simply asking for accurate info. Like Joe Friday used to say on Dragnet...."Just the facts ma'am...just the facts!" DD |
12-22-2019, 01:29 PM | #15 |
Re: 8BA in 1937
V8: Thanks for pointing out that major difference. I also noticed that in the photo above, the radiator looked surprisingly vertical unlike the typical 37 car. To an unknowing person with a '37 car, YOUR info. is vital. That's why it's so important to give the full particulars when one offers up a solution. I suppose there is the possibility that the poster didn't realize there is an difference in radiator angles.
12-22-2019, 03:17 PM | #16 | |
Re: 8BA in 1937
Well, I initially thought we might be able to use a '42-'48 fan hub also. I had a real nice one that I was going to send to Heard, but it's dimensions from the rear of the hub to the surface where the fan mounts was just too great, and every 1/8" inch was precious. The stock one just took-up too much territory. I just sent the mounting bracket to Heard which worked out perfectly...it's the one in our picture of the finished product on the car. Stock Ford hub and bracket below! DD |
12-23-2019, 12:55 PM | #17 |
Re: 8BA in 1937
Excellent.
12-23-2019, 05:11 PM | #18 |
Re: 8BA in 1937
The set up is great. Is this done with the Drake Hub? Who is Heard? Better to ask ask than assume!
12-23-2019, 05:52 PM | #19 |
Re: 8BA in 1937
Derby....No, we did not use the Drake hub. The Drake FAN hub is a reproduction of an original 1942-'48 Ford fan hub (like the black one in the picture just above). I had one but it turned-out to be too long for the available space between engine and radiator.
Heard is the FordBarn member that owns the primered '36 Ford 3-window coupe in the picture. It has an 8BA engine in it, and the radiator leans back just like on a '37, severely limiting the space for a mechanical, engine mounted fan. Heard wanted to get rid of the inefficient and ugly electric fan which had been mounted on the engine side of the radiator. We ended-up using a NOS Chevy Corvair fan hub like the one in the picture below. It is quite compact, yet plenty beefy enough to spin the great big cooling fan that was on top of a Corvair engine. If you like this concoction and have any more questions, I will happily walk you through any details. If you re-read the original link below-(Post #12) in it's entirety, some more of the details may come to light. DD https://www.fordbarn.com/forum/showt...mechanical+fan |
12-24-2019, 09:10 AM | #20 |
Re: 8BA in 1937
I know this is of no help just for conversation; but early 1970s I put a 8BA in my 36 4dr
didn't use chatter rods Those days I only had basic tools I do not remember any problems sliding that engine in. For the life of me I can't remember what I did with the fan, but some how I did it all with Ford parts laying about the barn. I drove that car 10yrs to work with no issues no heating no chattering and I heard its still running the roads same engine as I speak. So it is do-able maybe I used truck merc or even Lincoln fan parts???? sam |
