Old 12-07-2019, 10:16 PM   #41
little howard
Default Re: Help with a family issue
A stock 32 gas tank will mount in the stock spot, under the bed, in a 32 pick-up. There is one cross brace that has to be notched, and it's a pretty big notch, to clear the sender/pickup.
I use the stock filler, and put an access door in the bed floor above it. And, you can't see it from behind, and it might be a little safer in a rear end crash because you've got a foot and a half of bed hanging out behind it.
I've run my hot rod pick-up many miles this way.
little howard is offline   Reply With Quote
Old 12-08-2019, 10:24 AM   #42
RKS.PA
RKS.PA's Avatar
Charlie, it probably dawned on you long ago that you are blessed, as am I. We have wives that support us in this old Ford hobby, regardless! And....those smaller hands sure come in handy at times!!
RKS.PA is offline   Reply With Quote
Old 12-08-2019, 05:34 PM   #43
al's28/33
al's28/33's Avatar
should never have told her that, my wife is on a "needs to know" basis, and what happens in the Barn, stays in the Barn!!!!
1928 "A" Phaeton (mid year with many early features)
1933 "V8" Closed-Cab Pickup Truck
(originally a Model B, 4 Cylinder dating to May, 1933)
Old 12-08-2019, 05:55 PM   #44
FrankWest
FrankWest's Avatar
wives are the greatest...
all long time ago my wife and I were discussing what king of tires to buy.
My wife added, I think you should get Radio tires.
I looked at her and answered, AM or FM?
FrankWest is offline   Reply With Quote
Old 12-10-2019, 09:48 AM   #45
uncle buck
uncle buck's Avatar
Originally Posted by DavidG View Post
Michael,
It's not a Model A. '32 commercial gas tanks do not vent inside the cab unless you operate the vehicle without floorboards, which is a whole set of real dangers.
David,
If I understand the truck tank design, the venting is through the fuel sender which installs from the bottom of the gas tank?
uncle buck is offline   Reply With Quote
Old 12-10-2019, 11:00 AM   #46
DavidG
DavidG's Avatar
Yes, please see post #25 above.
Old 12-10-2019, 01:29 PM   #47
FrankWest
FrankWest's Avatar
Originally Posted by uncle buck View Post
David,
The My sedan fuel tank vents from the top of the tank.
Old 12-10-2019, 01:52 PM   #48
35fordtn
35fordtn's Avatar
Passenger car tanks are a whole different animal... in comparison to a 1932 Pickup tank
Old 12-10-2019, 10:37 PM   #49
Clem Clement
Clem Clement's Avatar
I thought all tanks were vented?
Old 12-14-2019, 10:27 AM   #50
JRHASZARD
JRHASZARD's Avatar
C-5 Galaxy has a fuel tank inerting system in which the ullage area is saturated with nitrogen. Also, as the fuel enters the tank, it is "swirled" causing it to release dissolved oxygen which would otherwise be released as pressure in the tank drops as the airplane climbs. I think I will take my zippo and peer into the neck to see if my 39 pickup has this same system.
JRHASZARD is offline   Reply With Quote
