Old 11-23-2019, 09:46 AM   #1
nelsb01
nelsb01's Avatar
Default Re: Body Mounting Pads 1937 1938 1939 open car & 1940 1941 Station Wagon Sedan Delive
Since Third Gen has re-opened Fordbolts -- why not check with them?
The catalog still shows that they may have them.
nelsb01 is offline   Reply With Quote
Old 11-23-2019, 12:54 PM   #2
35fordtn
35fordtn's Avatar
Originally Posted by supereal View Post
Body mounting pad kits are available from C&G (800) 266-0470. For 3740 order 78-5001, $45. There is no listing for wagons or sedan delivery. I use the tapered wood shims used in installing building doors. Like the "real" shims, they are wood. The taper between the shims allows adjustment to fit as you progress. Pay particular attention to the door/body gaps. Over the years most vehicle frames have shifted, so the kits may not always fit the gap
That is the set for closed cars not convertibles
Bruce the catalog does show them but like many things, there were none there and no samples or notes on them.
