Old 10-27-2019, 08:41 PM   #1
dbtenner
dbtenner's Avatar
Default 35’-36’ Water Pump - Pulley Removal
How do you remove the impeller and or pulley? The impeller side is not a nut. It looks pressed together.
Anybody run across this?
dbtenner is offline   Reply With Quote
Old 10-27-2019, 08:54 PM   #2
FlatheadTed
FlatheadTed's Avatar
Default Re: 35’-36’ Water Pump - Pulley Removal
Db ,Sit the impeller on your open vice then drive the shaft through with a drift ,sometimes its pinned ,
http://www.flatheadted.com
Flathead Ted brake Floaters ,
Old 10-27-2019, 09:12 PM   #3
dbtenner
dbtenner's Avatar
What is pinned? Can I use a stamp and use a mallet to hit the center rod thru the pump?
Old 10-27-2019, 09:26 PM   #4
Andy
Support the pump mounting flange and hammer the pully end of the shaft in the pully. I will drive the shaft and impeller out the back.
Andy is offline   Reply With Quote
Old 10-27-2019, 09:40 PM   #5
DavidG
DavidG's Avatar
It is only the later and service pump impeller shafts and pulleys that are not "pinned". Production pumps through '36 have a tapered pin holding the pulley on to the impeller shaft. That pin on the front of the pulley must be driven out in order to remove the pulley from the shaft.
Old 10-27-2019, 09:46 PM   #6
dbtenner
dbtenner's Avatar
Mine could be pinned? I can’t drive the rod thru the pulley end. It’s enclosed.
Old 10-27-2019, 10:22 PM   #7
DavidG
DavidG's Avatar
Search for opposing small holes in the front protrusion of the pulley in which there would be a pin running through the shaft. If there are no holes then there is no pin and the pulley is one of the pressed-on versions.
Old 10-28-2019, 08:41 AM   #8
JM 35 Sedan
JM 35 Sedan's Avatar
As usual, DavidG is right on the money with his info on the pin in pulley. You MUST drive that pin out from its smaller end, while making sure the opposite side of pulley is supported.
The pin is the only part I drive out. I use a press to push the main shaft out, pushing on its pulley end, while the back of the pump housing is supported by a steel tube that allows clearance for the impeller and shaft to come thru, and out the back of housing. I've taken at least 100 of these 32 - 36 pumps apart, and found this is the best way.
If you start hammering on the main shaft that may have a very tight press fit on pulley to shaft, and impeller to shaft, you're probably going to break the housing in many cases.
John
Old 10-28-2019, 02:51 PM   #9
FlatheadTed
As Andy says ,I have done plenty like that ,use the vice to support it ,you can drive the small pin out using the vice as well with a nail punch ,you can press the shaft if you have a press but this works as well .
I have never seen one pinned. Maybe a repair?
Old 10-30-2019, 10:59 PM   #10
dbtenner
dbtenner's Avatar
Thanks for the helpful advice. Wish I had a hydraulic press.
After rebuilding the water pump, is there a specific grease I should apply through the connection point?
Old 10-31-2019, 07:26 AM   #11
Frank Miller
Frank Miller's Avatar
On later pressed on pulleys I have hated the pulley and gotten it to easily come off the shaft.
“The technique of infamy is to start two lies at once and get people arguing heatedly over which is true.” ~ Ezra Pound
Frank Miller is offline   Reply With Quote
Old 10-31-2019, 09:55 AM   #12
Hoop
Hoop's Avatar
The pulley itself is easy to break ... BE CAREFUL not to put pressure on the pulley rather than the water pump housing.
Do not put blocks or press plates under the pulley rim. The idea is to drive the shaft through the water pump housing with the pulley sort of in the way. Do not pry or beat on the rim of the pulley.
Lots of broken pulleys out there.
"Remember that when it comes to intelligence, half of all of us are below average."
Hoop is offline   Reply With Quote
Old 10-31-2019, 02:19 PM   #13
FlatheadTed
Grease. you want a lot melt grease ,there used to be a water pump grease available ,Corn head grease might do it, but others may comment on that , there's nothing available here so I make my own mix of oil 3 to one of grease seems to work ok,I fill the cavity then don't add any for a year or two or three otherwise it will get into the radiator, Run the belt loose , melt out all the old grease first .
