#1 | |
![]() Quote:
IMO, and from what I have read. Some of this is debatable. Non-detergent multi grade oil was not available in the 30s. Sludge filth settled out and also adhered to the surfaces of the oil system, so the circulating oil somewhat stayed cleaner. Periodic maintenance/service including dropping the oil pan and removing the valve access cover to clean out sludge and the oil pump filter. Issues arose if the shade tree or typical owner for the A skipped or did not know this, and this service was not performed. So non detergent oil is ok, as long as you periodically service the oil pump screen, valve access area, and the oil pan/bottom end. It may even be preferable since the filth settles out and not as much filth is constantly circulating in the oil. For multi grade detergent oil, all the filth stays suspended in the oil. So unless running an oil filter, all of what is in the oil is constantly being circulated through the moving parts including the Babbit or Inserted main bearings. This is why since my motor is does not have an oil filter I prefer to change every 500 miles. Oil is cheap compared to the cost/hassle of rebuilding a motor. |
#2 | |
![]() Quote:
So accordingly I'll assume from the sound of your response you use non-dispersant. Thats your choice. I'll agree oil is cheap insurance, doesn't take long to change it. |
#3 | |
![]() Quote:
As a side note, saw my father once pour something (kerosene?) in the oil in of one of his old tractors and running the tractor for a couple of minutes before draining the oil (he collected old Masseys). I asked him about it. Told me his father did this occasionally on his tractor and on his Model A to flush the motor instead of dropping the pan to clean out sludge. On the tractor added it , ran the tractor a minute or 2 at idle, drained it, then filled with new oil. On the A, added the flush, ran the motor for 1-2 minutes at idle, drained the motor, would pour 2-3 quarts of old non contaminated oil through the distributor hole and breather/fill tube to clean out the oil galley and dipper tray and let it drain. Then filled with new oil. Just saying this is what my Grandfather with 5 kids with a live in house keeper since wife died due to complications of child birth, and was a dirt poor subsistence farmer who sharecropped in Minnesota/South Dakota did - not sure if this is ok to do. |
#4 | |
![]() Quote:
I Typically add ZDDP to my 20W/50 Oil Changes. to Each there own. |
First question is, does he use the thermostat ?
Model A by nature is a cold running engine so using a thermostat will make the 'magic' happen using a multi weight oil. No thermostat, I'd suggest being safe by sticking to a good straight weight oil. JB of the 'Flat Earth Society' |
