09-06-2019, 11:34 AM | #1 |
Banjo Rear Rebuilder needed in NJ
I'm looking for recommendations for someone in New Jersey area that can rebuild a Banjo Rear. Any help would be appreciated.
Thanks, Dan |
09-06-2019, 01:58 PM | #2 |
Re: Banjo Rear Rebuilder needed in NJ
Try Jim’s classics. He does complete restorations on early Fords. Small shop, very reasonable. Call and leave a message he’ll call you back
732 521 9383 Located in Monroe.
Thanks Andy 1952 F1 |
09-07-2019, 04:37 PM | #3 |
I just completed a compete rebuild and gear change on a 1935 Ford banjo rear changed from 411 to 325 gear. Not that far from Jersey.
Ronnieroadster
I use the F word a lot no not that word these words Flathead , Focus and Finish. "Life Member of the Bonneville 200 MPH Club using a Ford Flathead block" Owner , Builder, Driver of the First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921 in one and a half miles burning gasoline. First ever gas burning Ford flathead powered roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH |
09-07-2019, 05:56 PM | #4 | |
Every time he & I talk, I learn something new. I’m impressed by his knowledge and mechanical and machining abilities. I’m sure I’m embarrassing him a bit by gushing on like this, but it’s all true. |
09-07-2019, 06:21 PM | #5 |
He takes "gushing" well.....................
Paul in CT |
09-07-2019, 06:27 PM | #6 |
09-07-2019, 09:18 PM | #7 | |
Well I have to admit better fuel economy and lots more top end speed. Now you guys are letting the secret out Im not only good at making lots of power out of our beloved valve in block engines but also helping get more miles per gallon.. LOL
09-07-2019, 09:57 PM | #8 |
09-09-2019, 05:00 PM | #9 |
Ronnieroadster: Please call me, 732-341-0008, regarding rebuilding a banjo rear for my 1939 pickup.
Thank you, Dan Last edited by Dan 1939; 09-09-2019 at 05:02 PM. Reason: send to correct person. |
