Old 09-09-2019, 07:51 AM   #5
phil pavicich
Default Re: 34 front engine mount /water outlet
Originally Posted by Charlie ny View Post
Phil,
I have some....they are originals. I machine off the rotted water snout and
and counter bore into the now solid iron. I renew the proper length snout with an iron sleeve that is step turned and pressed into the orig casting. In addition to the press fit on the sleeve I use JB long setting epoxy. No issues, some Barners are using them. I
would certainly welcome any comment either way.
Charlie ny
[email protected]
Thanks Charlie , me being a machinist i will do the same to mine , thanks for the info cheers Phil
phil pavicich is offline   Reply With Quote
