08-31-2019, 09:41 AM
#10
Re: The dreaded death wobble
Originally Posted by 29Cabriolet
I replaced the rubber insulator on the radius rod about 4 years/3000 miles ago. What is the life expectancy?
What is meant by "the rubber insulator on the radius rod".
Are you referring to the rubber ball on the ball on the radius rod? If so, yes replace it as they get oil on them and degrade after time
OR reinstall the stock setup.
I may be off base but that is where I would start.
