Old 08-30-2019, 01:58 AM   #6
Tom Wesenberg
Tom Wesenberg's Avatar
Default Re: About half Model A related
Originally Posted by JBill View Post
I've seen videos of people changing Model A tires with the wheel still on the car. Has anybody here ever changed the rear tire of their lawn tractor with the wheel still on the axle? Can't get my wheel off.
I installed tubes in my lawn tractor because the tires always had a slow bead leak. I still have the scar on my left hand from the job, and it wasn't easy. Jack up the one wheel and lock it if you can, then use a hammer and large screwdriver or tire iron to push the bead inward. Wear leather gloves, just in case the hammer hits your hand, as it did mine with no gloves on. Then use some tire irons or screwdrivers to peal the tire off the wheel.
BTW, what size is the tire? The smaller they are, the tougher they are to change.
