08-22-2019, 09:53 AM | #1 |
Tips/suggestions for driving rear bearing on to shaft on a '39 transmission
I'll post a picture shortly, but I'm 90% done with the rebuild of a '39 trans. All parts (gears, cluster, bearing, etc.) are NOS. I've found the front and rear main bearings quite tight. The bearing for the front shaft went on with some encouragement with a dead blow.
Now I got the cluster and main shaft in the case, resting on the cluster and the rear bearing is being a bugger. I thought of tipping the trans on to it's bell and use a PVC pipe from the top to drive it on. Any tips or suggestions would be welcomed. |
08-22-2019, 10:10 AM | #2 |
Re: Tips/suggestions for driving rear bearing on to shaft on a '39 transmission
Press the bearings on before you install the shafts.
Bob |
08-22-2019, 10:14 AM | #3 |
It won’t go into the case that way. I spoke with Paul Jennings and have a plan.
08-22-2019, 10:18 AM | #4 |
Yes, tip the trans on end but the shaft needs to be supported individually. Heat the bearing in a preheated oven set at 200 degrees for 10 minutes. If the housing bore and the shaft are both clean of burrs and other crap, the bearing should glide right on. And, I wouldn't hesitate to use a steel pipe instead of pvc. It is common practice to heat bearings in hot oil but if you keep the temperature down you wont have a problem. Just work quickly during this install.
08-22-2019, 10:42 AM | #5 |
they are a tight fit but you can use the bolt hole on the end of the main shaft to press them on a bit then switch to the U-joint and continue to press it on all the way.
08-22-2019, 10:46 AM | #6 | |
Thanks, fellas. |
08-22-2019, 12:48 PM | #7 | |
Interesting, I looked at Mac Van Pelt's book again and he has the the output shaft assembled and installs it from inside the trans case moving it towards the rear then installs the snap ring. Bob |
08-22-2019, 01:44 PM | #8 | |
Ah, I understand what you are suggesting now. At first, I must of been thinking of something different. I'll try that too. Tim |
08-22-2019, 03:23 PM | #9 |
OK, could be I'm doing something wrong, but the rear bearing needs to go on after the back part of the shaft is in the case. It won't fit otherwise.
08-22-2019, 04:06 PM | #10 |
Got it on. A little polish, a little pipe, putting bearing in the sun for an hour and a BFH. Tight as a drum!
08-24-2019, 06:33 PM | #11 |
I use a threaded shaft I made up to screw into the end of the mainshaft,long enough to allow a sleave and washer to extend past the end of the mainshaft then fit the bearing and sleave over the shaft onto the inner part of the bearing,then a washer on the shaft and a nut and just pull the bearing on.
I sure would n,t be into polishing some off the mainshaft, then you have a loose bearing and U/joint to worry about. Lawrie |
08-24-2019, 06:53 PM | #12 |
Geez, I’ve never had one new or old that was tight on the main shaft,snug but not so tight it had to be pressed on and off.
08-25-2019, 07:39 AM | #13 |
I'm with you Ken. Never had a problem with that rear bearing.
08-25-2019, 07:49 AM | #14 |
I've rebuilt two '39 transmissions using NOS shafts and bearings, bearings slid right on the shafts by hand. Maybe should Mic the shaft and see what size it is.
