08-10-2019, 10:44 AM | #1 |
59AB thermostat
I just got my 59AB running well in a 32 Highboy. Even with a four blade fan 2 1/2 inches from radiator at idle parked in 85 degree weather the hottest it got was 140 degrees. New Walker radiator and those really good water pumps working well.
Are there thermostats available and where are they installed with Offenhauser heads. |
08-10-2019, 10:57 AM | #2 |
Re: 59AB thermostat
There are a number of threads on thermostats. The modern style ones install in the radiator hose at the outlet of the heads. You have to come up with a way to retain them or they will flip inside the hoses. A second clamp above the thermostat is an easy way to do it. You can also install a tube inside the hose above them, etc.
https://www.fordbarn.com/forum/showt...t=thermostates https://www.fordbarn.com/forum/showt...t=thermostates Last edited by JSeery; 08-10-2019 at 11:05 AM. |
08-10-2019, 11:41 AM | #3 |
Re: 59AB thermostat
The correct thermostats for the '48 and earlier Fords mount in the upper hoses directly above the heads. The stats are made to slide up inside of the hose. See attached pix.
Stats in the 160-180 range what the factory recommended for year round use. Modern stats don't work well in an early flathead.
Bill.... 36 5 win cpe |
08-10-2019, 12:59 PM | #4 |
Re: 59AB thermostat
And why would that be?
08-11-2019, 05:14 PM | #5 | |
Re: 59AB thermostat
My 2 Flatheads both have modern stats , and both run under 195 - even on hot & humid 95 degree days . Just make sure your radiator is clean ! |
08-12-2019, 11:15 AM | #6 |
Re: 59AB thermostat
openings and restrict the flow of coolant through the engine and radiator. The best stats were Robertshaw number 360-160, 360-170 or 360-180. Sometimes they show up on the internet. G.M.
www.fordcollector.com |
08-12-2019, 01:14 PM | #7 |
Re: 59AB thermostat
So the Robert Shaw stays fit well in aluminum 59 style heads?
Those look like they would not turn like the flat ones. |
08-12-2019, 10:16 PM | #8 |
Re: 59AB thermostat
Blucar X2
08-12-2019, 11:11 PM | #9 | |
Re: 59AB thermostat
08-12-2019, 11:56 PM | #10 |
Re: 59AB thermostat
You would have to find those NOS. Check with third generation automotive.
08-13-2019, 05:34 PM | #11 |
Re: 59AB thermostat
After much research I have found that the Robertshaw 330-180 is highly recommended. As is the 360-180 also by Robertshaw. Does one work out better than the other and why.
08-13-2019, 08:45 PM | #12 | |
Re: 59AB thermostat
second numbers are the temperature they open at. 330-170 is the 330 type and opens at 170. G.M.
08-13-2019, 09:34 PM | #13 | |
Re: 59AB thermostat
Well maybe not. I thought I saw a reference to the 360 series but cannot find it now Last edited by qmdv; 08-13-2019 at 09:41 PM. |
