Old 07-30-2019, 08:32 PM   #1
Gordon Ellis
Default Re: 32 stock v8 tudor steering very hard
How does one go about removing the rubber bushing under the steering wheel?
Gordon Ellis is offline   Reply With Quote
Old 07-31-2019, 12:25 AM   #2
31Abone
31Abone's Avatar
Tnx all..I greased front end and put 140 gear oil in box..steering seems fairly sensitive quick so I think box has 13:1 gears , car is stock never been fooled with much..until this fool came along...June or july 32 production..i put 3.54 rear gears..trans is wornout but numbers match frame..so i have pull mtr. to rebuild..sc.
31Abone is offline   Reply With Quote
Old 07-31-2019, 03:21 AM   #3
Tom Walker
Tom Walker's Avatar
I am going to do this job on my 32 Tudor. I have searched the forum briefly and not found a post which "walks" the reader through the process from beginning to end, so I will try to do a good job with photos etc.
I do not have a steering wheel puller, so something will have to be made to do this job.
Then the correct bearing will have to be sourced. Thank you David, I will measure the ID of the column tube. I suppose it is possible there is not a bearing which is an exact fit, and some machining will be necessary, but I hope not.
Any more advice before I start would be most welcome!
Tom Walker is offline   Reply With Quote
