I installed some used defective LED lighting in my shop a few years back, They were so bright that I had to eliminate some of the bulbs, The only thing wrong with them is: they "flicker" some times. The fact that I have bad eyesight, makes it a big improvement. I also replaced most of the florescent tubes in the garage area. Well worth the effort and costs.
#2 | |
![]() Quote:
One reason Leds can flicker, is when they don't have full voltage. They do make dimmable leds now for rheostat dimmers. Putting a non dimmable older led on a dimmer switch will make them flicker. . |
