I have a six year old ford script repro battery that is marginal in starting the car. I have added water numerous times over the years. My hydrometer indicates the battery acid in each cell is very dilute and in the red zone. Can I add fresh battery acid to the cells and recharge? Thoughts..... Don't want to give up on the battery if possible. Don't want to have a safety problem either!
The hydrometer reads specific gravity and in turn, the level of charge. Wrong to assume that it needs more acid. I'd take it to a place that makes batteries so they can remove all of the fluid and replace with new solution. then charge and load test. At least they could rebuild with new plates and fluid. Places like this are few and far apart but there is one in my neighborhood which is not much help.
#3 | |
![]() Quote:
This battery was partially sulfated so I added a teaspoon of epsom salt to each cell also. I got another 3 months from that battery. |
Some of us used to do what Pete said when we were young and broke. The batteries would last for a while longer.
But, do not add acid to the water/electrolite in the battery. |
As a battery ages with constant discharge and charge cycles, the water will dehydrate out which will make the electrolyte more acidic in charge state until more distilled water is added. If you add electrolyte instead of water, it will eat the plates up more rapidly. The lead plates deteriorate from acidic action as well as the added sulfation that happens over time so a battery's life depends on constant use to lower the amount of sulfation over time and careful adjustment of electrolyte so that the plates will have a relatively long life. If it's already sulfated or the plates are deteriorated, then it is close to its end of life. You can try the drain & refill but you need to be sure it is close to fully charged before you drain it. The epsom salts treatment may help the sulfation but there is no way of knowing how much. It's a fair amount of trouble to do all this and it may be beating a dead horse. |
Battery acid about $10 a quart at Autozone.
I did a customer's sump pump battery (large but not huge) and it took about a gallon which came in a plastic bag (snip the spout, turn up and let it flow into the cells.) New batteries are around $100, or $30 for the acid - and the hassle, and the hazard, and the possibility of failure. Joe K
Shudda kept the horse. |
The problem with forcing the last little use out of a lead acid battery is that they gas a lot, and they are at higher risk of exploding
i only ever got 3 years from the script batterys, all other batterys lasted 7-16 years |
Colonel, in an old car-mechanis book at the 50th I read how to regenerate sulfatet batteries: You should load the Batterie with only 1/50 amperes of there capacity over 60 hours. The filling-in caps must be open, refill destilled water is nececary because the acid bubbles a little bit over this long time.
Perhaps this awakes your old Ford-batterie again. Last chance?
Beste Gruesse aus Deutschland, Werner Ford Model A, Roadster, 1928 Citroen 11 CV, 1947 Hercules W 2000, 1976; (with NSU-Wankel Rotary Engine), Canadian version |
Use a desulphater?
#11 | |
![]() Quote:
Lead acid batteries use a diluted sulfuric acid for electrolyte. As a battery sets unused, the sulfates start to build up on the plates from the separation of the water and sulfuric content (electrolyte breakdown). During a discharge such as hitting the starter motor, the sulfuric compounds vaporize a bit and go back into solution during the charge that takes place after the generator kicks in. If a battery sets unused for 30 to 50 days without discharge & charge cycles, the sulfation that builds on the cell plates only partially comes off due to a thickened state of build up on there. If it builds too much, it will short between the plates of the cell and reduce its ability to give a normal discharge and take a normal charge. Even one dead cell can kill a battery's capability to function normally.
Discharge can be just as important as a charge. Charging at a very low amperage rate as was previously mentioned can help reduce sulfation or at least soften it so that it can go back to normal discharge & charge cycles again. Batteries need to be used or they will die a quick death. |
#13 | |
![]() Quote:
