07-05-2019, 01:26 PM | #1 |
Timing
The rotor inside the distributor has a wide contact. Should the #1 terminal be centered in the rotor contact?
After using the timing pin to find tdc. If someone do I loosen the distributor body to center it?. Thanks Dick |
07-05-2019, 01:46 PM | #2 |
Re: Timing
No. You loosen the distributor cam to change the timing. At full retard, the trailing edge of the rotor contact should line up with the #1 terminal.
07-05-2019, 01:47 PM | #3 |
Re: Timing
07-05-2019, 05:02 PM | #4 |
Re: Timing
Do you have the "Red" mechanics book??
Paul in CT |
07-06-2019, 03:55 AM | #5 |
Re: Timing
Yes I have it
Thanks Dick |
07-06-2019, 06:53 AM | #6 |
Re: Timing
07-06-2019, 01:03 PM | #7 |
Re: Timing
Gap the points before timing via the cam.
07-06-2019, 01:34 PM | #8 |
Re: Timing
Good idea to gap the rotor and the distributor body contacts too.
07-06-2019, 03:43 PM | #9 |
Re: Timing
Also keep in mind the rotor turns counterclockwise
07-06-2019, 09:47 PM | #10 |
Re: Timing
