Old 06-28-2019, 09:33 PM   #11
30 Closed Cab PU
Default Re: Locating dimple on timing gear
I had problems 1st time, then found the tip about lining the rotor up with the #1 contact, still was not easy until I found it. Was looking for more of a depression and was tuning the crank too fast. Once I did it once or twice, then it was easy.
