Old 06-28-2019, 03:12 PM   #1
alexiskai
alexiskai's Avatar
Default Re: Locating dimple on timing gear
Originally Posted by Will N View Post
I find it amazing all the trouble folks have with just using the stock timing pin as designed with just the engine crank to turn the engine over. Maybe I'm lucky in that my timing dimple is pronounced enough that I can locate TDC with no problem. Remove the distributor cap and crank it around until the rotor comes close to the #1 terminal. Remove the pin and insert and while standing between the bumper and radiator, with your left hand put pressure on the pin. With your right hand (and maybe with help from your right knee!) slowly crank it over and you will feel the pin move as it drops into the dimple. It's as simple as can be- no need for mirrors or timing marks or spring loaded doodads- just as Henry intended.
I think the main problem that people are inventing fixes for is the scenario where the rotor isn't already in roughly the right spot. A lot of distributor projects require removing the rotor and cam, or maybe the distributor was removed and then the engine position shifted while it was off.
In these cases, the need to potentially crank the engine through an entire cycle while feeling for the dimple is tedious and frequently strenuous. I often overshoot the dimple when doing this and have to back up or crank around again. So it doesn't surprise me that various workarounds have emerged as everyone makes up expedient solutions to a common problem.
