#21 |
wow Hard crowd not liking facts !!!
#22 |
Well, when you read some of these message boards, you see a whole lot of dis-information so I guess it comes with the territory.
#23 |
I always suggest an owner of a classic or antique car should try to get all the factory information for that vehicle that they can. If you sell the car, the books will help the next owner. This stuff is now available on CD for those that don't want books.
Some questions require actual experience to answer but most of them require factual information from the OEM sources. Those that want a custom car with none of the original equipment installed have to rely on trial and error or someone else's trial and error. |
#24 |
I had a 64 Marauder 390 4 speed car with manual steering and brakes. Car had rather plain looking steering wheel and horn button, found a park lane with power steering had a beautiful wheel so I swapped. The P S wheel was smaller and it made already hard to turn car even harder.
#25 | |
![]() Quote:
Both my '64 manual steer BB Galaxies had larger steering wheels than a friends power steer BB '64, just don't remember the actual measurements. |
#26 |
He crewed on a roundy round race car for a number of years. The body shell was Camaro and the drive train with exception to the 9-inch rear was Chevy but the frame & suspension was 1963 Ford Galaxie. They did well with that car on the dirt tracks at Dodge City and Huchinson KS. |
#27 | |
![]() Quote:
#28 | |
![]() Quote:
#29 | |
![]() Quote:
#30 |
Does anyone know if Chevrolet did the same thing with their steering wheels?
Matt 24:36-41 |
#31 |
My last '64 was manual and I had Pirelli 14" radials on it. That steered nicely. But I think bias ply would steer easier over radials in general.
On my '59, I aligned it with as much caster as possible, probably around +2 degrees, spec is around +1/2 to +1. That has 215/75 radials up front, the car is tough to steer going slow. I grab the steering wheel underhanded, not from the top. More leverage. I believe the bigger radials contribute to it, I keep them at 32 psi. I might go as high as 34 as a test. When finishing a turn navigating a parking lot, does the wheel come back by itself? If it does, the toe adjustment is probably good. But toss a little more positive caster into it and see how it goes. You can change it yourself and not change the camber. Just jockey the shims back and forth on the a-arm equally. What you take out of the front, place it in the back and vice versa. This is what I used to do for alignments where I didn't want to put it back on the rack. |
#32 |
I'm wondering if the Lower Control Arm offset Bolt could contribute to my problem? I should have upgraded it to a Born Again Classics conversion when everything was replaced. The mechanic said the OEM bolts were in good shape but now knowing it was a bad design in the first place. Should have done my homework.
#33 |
I wonder if the concentric off set shaft has an impact on the steering effort issue
#34 |
So, what are the part numbers/descriptions from the MPC for the steering wheels on a '63 or '64 Galaxie with and without power steering? We're waiting...
Alan H. Tast AIA, LEED AP BD+C Technical Director/Past President-Editor-Publications Director, Vintage Thunderbird Club Int'l. (VTCI) http://www.vintagethunderbirdclub.net Author, "Thunderbird 1955-1966" & "Thunderbird 50 Years" 35+ year member, Crown Victoria Ass'n. |
#35 |
I have a '60 ford fairlane with BIG wide tires all the way around, manual steering, stock steering wheel and I can turn the wheels at a stand still with 2 fingers on the steering wheel, no lie!
#36 | |
![]() Quote:
63/64 A (w/o PS) Black 17' EDIT 17" Dia - C3AZ 3600-BA 64/ (w/ PS) Black - 16" Dia - C3AZ 3600-CA
- WANNA SEE A GOOD CAR WRECK? - https://www.youtube.com/watch?v=5oO226PgSkg KULTULZ - HAS MOVED ON TO THE HAPPY PROVING GROUNDS Last edited by KULTULZ; 06-25-2019 at 12:54 AM. Reason: FAT FINGERS - SHORT EYEBALLS |
#37 | |
![]() Quote:
Considering the fact that all my driver '63 Galaxies were manual steering (even a '63 XL 4-door HT with 352/COM, no power brakes either), I had nothing for reference, though I did part out a '63-1/2 XL but never compared wheels. A 17-foot diameter wheel, though, would REALLY give someone "leverage" ![]()
#38 | |
![]() Quote:
- WANNA SEE A GOOD CAR WRECK? - https://www.youtube.com/watch?v=5oO226PgSkg KULTULZ - HAS MOVED ON TO THE HAPPY PROVING GROUNDS |
#39 |
Not to undermine all the discussion about width or composition of tires, which certainly needs considered, have you ensured that the tires are properly inflated? I've found that when one of my "old" cars has the situation you've described, that the tires need inflated to recommended, or very slightly, higher, PSI. Even though you can eyeball the tires, and they look fine, put a gauge on them, and see if they can / should be inflated a bit more. It makes a difference and might help your situation.
#40 |
As was mentioned above, I think a lot of the problem is the tire/wheel combination on the car. Without power steering, the wide tire must be a bear to turn. Must have zero flex in the tire which probably does not help.
