#11 | ||
![]() Quote:
If I was going to look to set any legitimate records today with the Flathead ( I'm not, believe me) I would most likely run it "Turboed", injected, and possibly on E-85, if not, on race fuel for sure! Definitely would be walking in "blind" though on a build like this. I would assume it would have to be a "concreted" block, at least partially anyway! Thanks, Gary in N.Y. P.S. While I have some peoples attention here I just got a phone call from a good friend and was told to expect to see a 25% increase in ALL off-shore cranks. After he hung up I made my own call to one of the larger mfr's and confirmed his info, it IS correct. This will affect the Flathead cranks and, I suppose, all the off-shore conn rods also! If you're contemplating a stroker in the near future you may want to pick up the crank/rods now and "stash" them??
http://www.stromberg-bulletin.com/me...berg-equipped/ |
