Old 05-15-2019, 08:02 PM   #1
dgmgohl
Default Vacuum test
I have a 53 Merc 255, and I'm preforming a vacuum test of the intake. I'm reading 19. I can't find the right spec on where it should be. I was told around 25. If that's the case is there a way to increase the vacuum to normal specs?
dgmgohl is offline   Reply With Quote
Old 05-15-2019, 08:42 PM   #2
BUBBAS IGNITION
BUBBAS IGNITION's Avatar
Default Re: Vacuum test
Let google be your friend .........
If it Makes Spark, we do it !!!!
www.bubbasignition.com
[email protected]
BUBBAS IGNITION is offline   Reply With Quote
Old 05-15-2019, 08:50 PM   #3
Talkwrench
Talkwrench's Avatar
Normal vacuum on a good engine at sea level will be 21Hg. the "norm" is between 17 - 21Hg.
Old 05-15-2019, 08:50 PM   #4
19Fordy
19Fordy's Avatar
Actually 19 isn't bad, I think.
Old 05-16-2019, 05:46 AM   #5
Ggmac
If it's a steady needle, that's not bad .
Old 05-16-2019, 06:24 AM   #6
tubman
tubman's Avatar
This is assuming a stock engine. Aftermarket camshafts can cause lower vacuum readings.
Old 05-16-2019, 07:01 AM   #7
37 Cab
37 Cab's Avatar
As can timing adjustments. Slow timing= lower vacuum
Tommy
37 Cab is offline   Reply With Quote
Old 05-16-2019, 08:58 AM   #8
Ol' Ron
Ol' Ron's Avatar
19 is very good especially if the needle is steady. You might want to 'Tweek" the idle screws on the carb, for more, but?
Old 05-16-2019, 11:05 AM   #9
scicala
scicala's Avatar
I would be more than happy with 19" with a stock camshaft.
Sal
scicala is offline   Reply With Quote
Old 05-16-2019, 07:53 PM   #10
Flathead Fever
Flathead Fever's Avatar
Its good at 19 especially if your at a higher elevation. Another test is to snap the throttle open and closed and see if the reading momentarily goes up even further, then drops back-down to 19. That tells you your rings are seating well.
Old 05-17-2019, 12:53 AM   #11
Tinker
Tinker's Avatar
19" is solid. 24-25" would be too much at idle in my opinion no matter the elevation (that's if you take the measurement at that elevation).
As mentioned google is your friend. many articles on it.
Oldie but a goodie.
