05-10-2019, 08:05 PM | #1 |
re Adjusting 34 Cabriolet Doors
A while back I took a scan of a page from a Ford Bulletin that I found on-line of a page of detailed instructions on the adjustment of 34 Cabriolet doors. Unfortunately and stupidly the scan I made was so low resolution that when I printed it I cannot read the issue or page number of the relevant Ford Bulletin and my copy of the Ford Bulletin Book does not have it in for some reason. Does anybody recollect seeing this article, it's headed 'Door Adjustment' ?
05-10-2019, 09:16 PM | #2 |
Re: re Adjusting 34 Cabriolet Doors
What you will deal with is having to get gap between the door and the quarter panel even. On my '32, the top rear corners of the doors were tight against the quarter panels, even overlapping them a little. While the bottom were okay on both sides after I had bent the lower hinges. What worked best for me was to bolt the four corners of the body down. Then I put a floor-jack and a block of wood under the floor beneath the door gap on the driver's side and jacked it up until the upper door gap spread apart to where I wanted it. Then I installed automotive alignment shims between the body and frame and tightened them down. It looked perfect. Then I did the same thing to the passenger side but when I went back to the driver's side my perfect gap had changed. It took a few trips back and forth to get both sides looking good. Dorman makes alignment shims in different thicknesses. Harbor freight sells a 144 piece assortment for $9.99. You can order them on Amazon too. The advantage is these shims are open on one side so you can just slide them in around the bolt without have to remove the bolt each time. They also have a little tab for removing them since you will be doing this a few times before your happy with it. |
