Old 05-09-2019, 09:48 AM   #40
Werner
Werner's Avatar
Default Re: Air filter for Model A
Error. With the sealed hole the engine was not adjustable and too rich. The ventilation hole in the upper housing is necessary to get air into the channel for the idle needle!
Blockhead: Meanwhile, I have the hose line as shown by you in the area of ​​the choke flap. Thank you!
Synchro: Your comment is correct. Nevertheless I have now the tube pipe layed to a short distance before the choke flap achsle to get a shorter pipe.
Thanks to the helpers! Now my engine sucks in dust-free air and the carburetor does not mix too rich.
Werner
Ford Model A, Roadster, 1928
Citroen 11 CV, 1947
Hercules W 2000, 1976; (with NSU-Wankel Rotary Engine), Canadian version
Werner is offline   Reply With Quote
