Old 04-21-2019, 08:11 AM   #4
51 MERC-CT
51 MERC-CT's Avatar
Default Re: Oil flow in a factory bypass system?
After the oil passes thru the filter it exits thru (2) i/16" holes in the center tube and out the bottom.
The center tube holes are at about the same level as the inlet tube and with the inlet fitting removed it may be possible to see at least one of the holes thru the inlet hole.
