Old 04-14-2019, 02:50 PM   #5
Garagekulture13
Garagekulture13's Avatar
Default Re: Timing Gear Back Lash
I had a knock also and it turned out to be my timing gear was worn badly. Here are a couple of videos of the sound the timing gear was making while running, hand cranking with the cover off and after a new timing gear.
The knock:
https://youtu.be/3R3eLKlvVmU
Hand cranking with timing cover off:
https://youtu.be/lDI6grnm-Z0
After new timing gear:
https://youtu.be/C-MMJRXug8E
I hope this helps.
Sent from my SM-N950U using Tapatalk
Garagekulture13 is offline   Reply With Quote
