Old 03-31-2019, 09:27 AM   #6
19Fordy
19Fordy's Avatar
Default Re: 39 rake
If you raise the rear to obtain a "rake" rear end gear oil will drain down the inside of your torque tube and destroy your torque center bearing. Of course, this assumes you are still using a torque tube with a stock rear. With a radical rake you will also need 2 jacks to change the tires. One to first raise the frame and another to raise the axle. Can you post a few photos of what you're dealing with??
