Old 03-19-2019, 12:03 PM   #6
30 Closed Cab PU
Default Re: Wiring for trailer
Originally Posted by Davew View Post
Thanks for the reply’s. I have a small blue sea fuse box I could use for this and was thinking of LED’s but wasn’t sure I could. I’m going to look at that Hersey plug and the marine grade wire. I want it to be as weather proof as possible. Thanks again. Dave
LEDs - just a suggestion, may want to contact the LED manf, think I remember everything on the same circuit needs to be LED, can not mix other types on the same circuit. If you are paralleling off the current wiring, everything has to be LED. Again I am not 100% sure, check it out before deciding.
