03-05-2019, 09:05 PM | #1 |
37 wiper motor restoration
Hi guys,
I have what appears to be a stock 37 wiper motor, driver's side. It needs to get installed ASAP. I will try testing it out with a vacuum source tomorrow. My question is, even if it works in some fashion, should I give it a refresh? For example, should I remove the top and clean/lubricate it? I have never had one apart so I don't know what to expect when the top cover screws are removed. I don't want to tear up any gaskets or have parts flying around. Maybe just a few drops of oil, here and there? I see a small hole above where the shaft is routed? Thanks for any advice/warnings. gregg |
03-06-2019, 02:36 PM | #2 | |
Re: 37 wiper motor restoration
Charlie Stephens |
03-06-2019, 03:35 PM | #3 | |
Thanks Charlie. I was going to use 3-in-1 oil. I will try to get some ATF in it somehow. I hooked up the motor to the car's vacuum and nothing happened when I pulled the lever. Well....maybe I should say not much happened. When the switch is pulled on the shaft turns a little in one direction. When the switch is pushed off, the shaft rotates back in the opposite direction. I got desperate so I decided to disassemble the motor unit. It wasn't too nasty inside. I cleaned it out and left just a touch of ATF lube. With the top removed, I moved the inside "flapper" mechanism back and forth. It all seemed to work manually, and there was a clean snug fit. During the re-assembly process, as I was tightening the last oblong head screw, the needlenose pliers slipped and plunged into the rotating mechanism on the front side. There is a rather fragile piece that rides on the shaft cam? and waddles back and forth as the flapper moves. The fragile piece went bye-bye and broke into pieces....damn. That is the end of that wiper motor. I can't believe there are replacement parts for the internals. Next, will try out a second wiper motor I have lying around somewhere. Lesson learned here, be careful! gregg |
