02-12-2019, 01:13 PM | #1 |
1955 T-Bird early(1954) VIN
I bought a 1955 T-Bird from a guy in Frankfort, Illinois last fall. It was in bad shape, and had been sitting in a shed since 1970"s. the number is 100231. making it the 231 T-Bird produced. I think it was october 1954. I had to replace the floor, trunk floor, rockers, and rear quarters. I am doing my best to make it a good restoration, I bought a rotissery to restore the body on. Best money I ever spant. and a plasma cutter and wire feed welder. I have done a few restorations and hot rods the past 20 years. so I do have some experiance. I was wondering , since there is no engine or transmission with it, if converting it to a 351 cleveland and c4 transmission would hurt the resale value a lot.
02-12-2019, 02:39 PM | #2 |
Re: 1955 T-Bird early(1954) VIN
First off, please register it at this website....
http://tbird.info/thunderbird-registry-faq.htm This Bird is AWOL http://tbird.info/registry/Results_last_six_list.php http://tbird.info/first-1955-thunderbirds.htm Among the right audience there is some added prestige to having a very low numbered '55 Bird. But it doesn't mean too much unless the car is original or has some other original unique feature. Example: one of the first ten built, has special trim, owned by a celebrity or FoMoCo executive, etc. Since the car isn't original anymore, unless it has an additional claim to fame, I see no reason a newer engine & transmission would hurt it's value in a significant way. If the work is well done it might even add some value for the right buyer. FYI, as you get farther along you'll notice an original '55 Temp gauge won't work right with an engine that has heads newer than '56. Not sure about the '55 speedometer cable into a newer transmission... Last edited by dmsfrr; 03-23-2019 at 12:30 PM. |
02-12-2019, 03:25 PM | #3 |
I think dmsfrr is right about that, a bird back from the dead probably isn’t worth the price for the missing parts. I’m a y block guy, but when you look at the bird only parts the price adds up pretty quickly.
It’s been years since I’ve been around modern small block Fords, but IIRC the Cleveland was the big dog in the performance department. Unless you’ve got one laying around, I’m not sure you’d get that back in a Thunderbird. I’d be more likely to look for a good 302 that can be converted to a carb is necessary, or retain the EFI is you’ve the ability to do that. Likewise the C4, unless you’ve got a good one in stock. They sell adapters for the C4 behind the Y, and those guys seem happy with it. If the car was originally an auto, you could also put a 302/AOD combo in it. If it’s still got the Dana rear end, those are not easy or cheap to change the ratio in unless you can do the work yourself, and even some parts can be a problem. |
02-12-2019, 03:54 PM | #4 | |
Isn't the 351 'Cleveland' block wider & taller than the Windsor blocks? That could be a more challenging swap. Clearance to the steering column and hood isn't the best. '55/'57 Birds have a rear sump oil pan, special exhaust manifold for the drivers side and a low-profile air cleaner too. With a higher horsepower engine if you upgrade to front discs and a dual circuit master cylinder the M/C could be very close to the head. . Last edited by dmsfrr; 03-23-2019 at 12:31 PM. Reason: added, rear sump oil pan |
02-12-2019, 06:06 PM | #5 |
I would suggest also that when you fabricate the mounts to install the newer drivetrain make it a bolt on affair in case someone with lots of $ and or the correct Thunderbird parts can go back to original if they so desire. I'm sure you will also be converting to 12V if your going to be using a newer drivetrain. Check out the CTCI website (Gil's garage) to see what information is there.
Yes the steering box can be a problem when putting in the different engine. Some guys use hi-po 289 exhaust manifolds if they can find them. Some guys go with headers but you need to find headers that will clear the steering box. I think you also need to look for a rear sump oil pan for the installation. |
02-12-2019, 07:57 PM | #6 |
02-12-2019, 08:03 PM | #7 |
I've seen 289, 302, 351W's in the little birds. The only issue is the engine is lighter than the original "Y" block so the front rises up a little bit (changing the stance of the car). Some people change out to Aerostar springs. They drop the front pretty much back to correct height. I've also seen 390's in the little birds. No issues with weight change because the big Ford engine weighs almost exactly the same as the original "Y" block. Just a little FYI.
02-13-2019, 10:10 AM | #8 |
The Cleveland 335 blocks are larger than the Windsor blocks. 302 or 351 are long but would fit better than a Cleveland.
02-13-2019, 05:25 PM | #9 |
thanks for all the info, I do have a 1974 302 here also that I was considering. I have lots of 351c parts, but the 302 is also complete . I have both engines in my shop now, so very soon I will trial fit each of them as I do have the body off the frame on the rotesey now. Lots of work, but the only way this old dog will ever own a '55 T-Bird! thanks again.Henry
02-14-2019, 08:34 PM | #10 |
I think in today's world if i were in your shoes I would find a wrecked new FORD product that has the latest and greatest modern day engine. Plenty of power with excellent mileage. Just my thoughts.
02-15-2019, 12:57 AM | #11 |
An early '55 I would put back to stock or close it. There are no matching engine numbers on a Y block so any block will do. Easiest way to get all tht T Bird engine parts is to look for a complete engine that somone has pulled to install something else. The come up occasionaly. I would make it a 312 to make it interesting. Doing all the body work would make it affordable. Most of us don't do this to get rich.
02-15-2019, 05:24 AM | #12 | ||
- WANNA SEE A GOOD CAR WRECK? - https://www.youtube.com/watch?v=5oO226PgSkg KULTULZ - HAS MOVED ON TO THE HAPPY PROVING GROUNDS |
02-15-2019, 12:13 PM | #13 | |
But there are casting numbers that are specific for certain model years, and foundry date codes on the castings. That is the Ford Y-Blocks version of numbers matching. Sal |
02-15-2019, 01:11 PM | #14 |
I have it registered with the T-Bird registry. thanks
02-15-2019, 01:13 PM | #15 |
I never make much money off my cars. Usually enough to pay for the expenses of building the car and a little left over to buy another disaster!!
02-15-2019, 07:07 PM | #16 |
An FE will almost be a bolt-in. but the hood won't clear. A guy I knew back in high school installed a MEL 430. Same problem. He stopped driving it because the police kept stopping him for no hood. If you would install either of these, the same problems as a y-block. A Cleveland is a huge piece of cast iron, with no advantage. A Windsor on the other hand is plentiful in any configuration, and can be had all the way up to 460 inches, with a corresponding increase in power and cost as you go up the scale. Windsor powered little Birds, and their reproduction brethren, are getting almost as plentiful as the other belly-button. Speaking of that, a guy I know almost has his 350 powered little bird finished. It's your car, cut it up if that's what makes you happy, there is no shortage of them.
02-15-2019, 10:16 PM | #17 | |||
Thank you
even if it's all wrong and seized. Unless you can see the back end of the crank or the main bearing caps you can't visually tell the difference between a 292 and 312. (photos below) Many sellers are 110% convinced any Y-block they have is a '57 312, and again will want top dollar. http://ford-y-block.com/identify312.htm 'Buy high and sell low' seems to be the way it often goes over here. Quote:
http://ford-y-block.com/Block%20identification.htm When I was looking for a replacement long-block for my '55 Bird I came across quite a few 292's from 60's pickup trucks. Since I already had nearly all the T-Bird specific parts from the existing engine this wouldn't have been a mechanical problem, but knowing in the back of my mind that the car would have an 'old truck engine' in it wasn't something I wanted. 39deluxecp Which way you proceed is of course up to you. Five years ago I decided to go the 'nearly stock' route mostly because I already had a (barely running) engine in the car and wouldn't have to reinvent-the-wheel for my first project in 25+ years. Not to mention that the biggest tools in my garage are a floor jack and impact wrench. No fabrication tools at all. After getting more time under the car and behind the wheel, if I were to try this again, esp without the needed Baby Bird specific engine parts on hand, I'd be more inclined to go with a newer drivetrain. (and an overdrive transmission) Last edited by dmsfrr; 03-23-2019 at 12:40 PM. |
02-16-2019, 08:55 AM | #18 |
If stock the 74 302 will be down on power a little, nothing serious but was the beginning of emissions. Nice smooth engine and the sky or wallet is the limit on horsepower if you want. Rear sump pans are easy to find, different styles for each car body style or truck from 1980 up all used rear/mid sumps.
02-16-2019, 10:06 AM | #19 | |
I cannot remember the specific numbers but I think the original 292 engine had a rating of around 180 HP. Then if I remember correctly the 302 for 1974 (due to all the emission controls and engine detuning) was rated at somewhere around 150 HP. If you have a good running 302 from 1974 and you put it into the car (need to be aware there will be issues in / around the steering box) you could probably get a little more HP out of it with a few modifications. |
02-16-2019, 02:02 PM | #20 |
i am considering the 351c with 2v heads because it will have more power than the stock 302 I have(the 302 does have a 4 barrel intake), since the stock 302 heads have such small valves and ports. I do think the c4 transmission will be nice, as the car has the 3.27 gears now. I do not go over 30 miles away from home with my old cars, just short and sometimes fast drives. It is 18* above zero right now, so even though my hanging gas furnace will heat the shop pretty fast, i have no desire to go into that shop in this weather! when i get some anbition, I will test fit the cleveland and the 302 and post some pictures of each.
