Old 02-06-2019, 09:28 AM   #10
rotorwrench
rotorwrench's Avatar
Default Re: What is this puller part for ???
I agree with Charlie on this. Ford banjo type drums should be pulled utilizing the groove in the nose of the hub like the KR Wilson tool was designed to do. The tapered fit and the torque of the nut along with corrosion and other factors makes them too tight to pull from the lug bolts
