Being new to the Model A, I am leraning something new everyday and today is no exception. When I was checking my water level, I noticed a rusty spec resting on the baffle however in order to remove it, I slightly moved the overflow tube and when I did, suddenly a steady stream of water starting flowing out of the bottom of the the overflow tube. Being that the water level was beneath the top of the tube, could I have agravated a crack in the tube? Do these tubes need to be in a specific position? Here's a photo of mine. The water is no longer coming out but the level has dropped a bit. I have a feeling I am about to read-up on radiator removal procedures.
If it aint broke, don't fix it! |
You may have just unplugged the o/flow tube.......
Paul in CT |
#3 | |
![]() Quote:
I was getting ready to put another radiator in the car and when I filled it up and plugged the bottom and top inlet/outlet water was coming out of the overflow and had to replace the overflow tube which had a crack in the tank area. Wasn't a problem for the radiator shop to replace the tube. It also ran over on the right side which wasn't correct, so corrected that also. |
Thanks for the replies. It is no longer dripping from the overflow but the water just barely covers the core. When I started adding some water it started coming out of the bottom tube again. I am pretty much convinced there must be a crack somewhere in the overflow tube between the top and bottom of the tank. Looks like I will be removing the radiator and taking it to a shop.
Try letting it find it’s own level,as long as you can see the fluid I think you will be fine!, remember these are not a pressurized system best of luck
Looking at the bottom of the overflow of the tube there seems to be a silver/shiny crack/break. Could be a crack, but then again could be water/damp, optics of the picture. With the motor not running you should be able to fill to the top of the overflow, but it starts draining when you get to the top of the core.
While at the radiator shop have them back flush it and check condition. When putting it back on, if you do not have one, add an upper hose coolant filter to keep the rust from the block getting into the radiator. |
It is common for that tube to rust through. Most originals had steel overflow tubes and in their past life, many were run without the rust prevention of antifreeze or other rust preventers. The cleaning process often removes the rust fron the steel and a leak suddenly appears.
#9 | |
![]() Quote:
Here's a quick fix, pick up a length of shrink tube that will just slide over the over-flow tube. Warm it up with a BBQ lighter and seal that crack.
#11 | |
![]() Quote:
The Master Cylinder Enjoying life at the beach in SoCal... |
Thanks guys. I may give that a try. Besides the cracked tube problem, I am still getting some seepage when the engine is warmed-up on the inside bottom seam of the tank where it meets the core so I may go ahead and remove/repair. Best, Steve.
#13 |
Yep, I would certainly take it off and have a shop leak test and repair. Not that big a deal to take it out, and a process you will repeat in the future. A tip I learned here: take the front bumper off before you start. It is only two bolts and makes the process much easier. I remove the headlights bar as well.
Bill Worden 1929 Roadster 1929 Briggs Town Sedan 1930 Closed Cab pickup Smith Motor Compressor 1951 Ford F1 High Desert Model A's |
#14 | |
![]() Quote:
#15 |
If you do the repair you can cheat a bit using the same size in copper tubing. it bends easily and will tin very quickly so soldering it in is easy. Once tested you can paint it with BBQ Flat Black and no one will be the wiser.
