Old 12-19-2018, 08:22 PM   #9
Licensed to kill
Licensed to kill's Avatar
Default Re: Vacume source
Originally Posted by 40cpe View Post
The 8BA distributor operates off of venturi vacuum, manifold vacum is too high. The 97 doesn't have a port for venturi vacuum. Your friend needs a centrifugal advance distributor. A small block chevy distributor converted for a flathead would be a good choice.
By "venturi vacuum" I assume you mean Ported vacuum and if so then the problem is with the carb model not having posted vacuum, not the number of them.
Licensed to kill is offline   Reply With Quote
