Old 12-09-2018, 03:06 AM   #1
Jeff M
Default Brake T Bolt
Is this the correct 91A-2150 front brake T bolt on the 39-48 passenger cars? It only has one outlet hole other than the inverted end that looks to screw into a hose. I've seen the reproduction bolts with that part number and they have two outlet holes on the side.
Jeff M is offline   Reply With Quote
Old 12-09-2018, 08:07 AM   #2
flathead48
Default Re: Brake T Bolt
Not sure but may go on passenger side where it dead ends at front wheel .
flathead48 is offline   Reply With Quote
Old 12-09-2018, 08:17 AM   #3
51 MERC-CT
51 MERC-CT's Avatar
Either one or two holes will work on the banjo bolt.
If it will make you feel better just drill the hole thru the other side.
Old 12-09-2018, 08:21 AM   #4
36rgtop
36rgtop's Avatar
Never saw a 'T' fitting or banjo bolt on the "passenger side"
36rgtop is offline   Reply With Quote
Old 12-09-2018, 09:33 AM   #5
51woodie
51woodie's Avatar
The banjo bolt on my '46 only had one hole, and there is no banjo bolt used on the passengers side. The brake hose on the passengers side clips in to a bracket on the frame, and the fitting on the steel line from the drivers side threads in to the end of the brake hose.
51woodie is offline   Reply With Quote
Old 12-09-2018, 09:36 AM   #6
Kube
Super Moderator
Kube's Avatar
That's the one...
Kube is online now   Reply With Quote
Old 12-09-2018, 03:18 PM   #7
Jeff M
Thanks for the replies, I'm putting hydraulic brakes on a Model A and ran the lines like the '39-'48 cars. I guess I was over thinking it, I figured it needed two holes in the banjo bolt to move fluid to the passenger line. Since the bolt shoulder drops off where the hole is drilled and each side of the brass block has copper crush washers I guess the fluid just moves around the bolt and fills all the space where it needs to go.
Old 12-11-2018, 09:38 PM   #8
Flathead Fever
Flathead Fever's Avatar
I've had some problems with the new copper brake washers leaking that are being sold. They are just flat smooth sided copper washers. The originals have the nice ridges in them that make the seal. I would reuse an old one with ridges before I would use a smooth one. I'm sure the correct ones are out there for sale somewhere?
Old 12-12-2018, 02:09 AM   #9
fordlovr
fordlovr's Avatar
Well then! Iv'e been having a problem with a small leek at the back of the master cyl. All new parts. I think there is a copper washer there. might swap for an old one I have somwhere.Thanks for sowing the seed!!
fordlovr is offline   Reply With Quote
Old 12-12-2018, 02:49 AM   #10
Phil Gillespie
Phil Gillespie's Avatar
Bryn,
If you do have a copper washer there you will get a better seal if the washer is annealed, before its fitted. heated up to a red heat then quenched in water. This will do the trick for seaing.
Phil NZ
Phil Gillespie is offline   Reply With Quote
Old 12-13-2018, 02:00 AM   #11
fordlovr
fordlovr's Avatar
Originally Posted by Phil Gillespie View Post
Bryn,
Phil NZ
Thanks Phil, Will try that
