All,
there is a Saturn rod bearing that will just fit between the studs/bolts. finish size on crank is 1.850 largest I could find and not have to move the main bolts. also, if HP is above 150, it is wise to weld up flange on crank and machine for 2 pc chevy seal. J
As Carroll Smith wrote; All Failures are Human in Origin. |
