Old 10-13-2018, 03:38 PM   #1
36coupe
36coupe's Avatar
Default Building a sleeve for a t170
I plan to build a sleeve for my T170 input shaft so I can use a and early through out bearing. A couple of questions.
1/ how tight should the ID be on the sleeve going over the transmission shaft?
2/ what is the best material to use?
Thanks
36coupe is offline   Reply With Quote
