Old 10-09-2018, 09:45 AM   #1
adileo
adileo's Avatar
Default Bad voltage regulator?
Hi guys
I’ve been noticing after I drive the 52 F1, white (looks like battery acid) powder all around engine. I took analog voltmeter, started engine, removed negative terminal connected volt metrr and at idle 6.5 volts. However, when I rev engine it hits 10 volts.
You agree bad voltage regulator?
Thanks
Andy
1952 F1
adileo is offline   Reply With Quote
Old 10-09-2018, 05:07 PM   #2
supereal
supereal's Avatar
Default Re: Bad voltage regulator?
To check system voltage place the voltmeter between ground and the BAT terminal on the regulator with the battery terminals clean and tight. If you see more than 7.5 to 8 volts at a fast idle, it is likely the regulator or a battery cell that is dying.
supereal is offline   Reply With Quote
Old 10-09-2018, 06:13 PM   #3
koates
Not sure when you say removed negative terminal (on the battery ???) because you don't test the voltage in the system that way. Follow supereal instructions above and leave the battery terminals connected. Regards,, Kevin.
koates is offline   Reply With Quote
Old 10-09-2018, 06:37 PM   #4
adileo
adileo's Avatar
Ok thanks guys. My simple logic, putting the volt meter inline with the battery would show the volts going to battery.
I didn’t think it was battery as the white crap (all over firewall and engine) was telling me it was over charging. Testing it the way I did and seeing 10’volts on meter while reving kinda was confirming in my simple mind. But I yield to you both as I know I’m not as experienced
Thanks I’ll try you way in am
Thanks
Andy
1952 F1
Old 10-09-2018, 06:57 PM   #5
koates
Believe me we are correct and you are doing it wrong. An ammeter can be connected in line with the battery to read charging current in AMPS as long as you don't operate the starter motor if doing this. The voltmeter is not normally connected in line with the battery but is connected across the battery terminals to read VOLTS. No point in guessing how to do something especially electrical systems otherwise results can be BAD, INCONCLUSIVE or even DANGEROUS!!! Regards, Kevin.
Old 10-10-2018, 01:52 PM   #6
adileo
adileo's Avatar
Connected as directed to voltage regulator. Reving engine the needle doesn’t go above 6.5 volts. Tried with lights on & off.
Thanks
Andy
1952 F1
Old 10-10-2018, 09:51 PM   #7
koates
If the generator and regulator are good then you should have around 7.5 volts with some revs up, around 2000RPM and hold for a minute or two to allow the voltage to stabilise. Approx 6.3 volts is the voltage of a charged battery at rest. so you see the battery is not being charged if all you have is 6.5 volts. Test your battery with a hydrometer or have it load tested and make sure it is not overfilled. Regards, Kevin.
Old 10-11-2018, 07:18 AM   #8
adileo
adileo's Avatar
Thanks, I determined when conducting the test the ground used was not good. I switched it to battery ground and now I’m getting 7-7.5 - all good.
Thanks
Andy
1952 F1
