Old 09-23-2018, 04:17 PM   #1
adileo
adileo's Avatar
Default 52 F1 solenoid
Hi guys
Trying to cleanup some of the trucks wiring. If you can make it out...there is a red wire going from the small terminal on the left to a ground (actually one of the solenoids mounting bolt) bolt. Is that really necessary?
Are the smaller outside studs grounds?
File Type: jpg D6D88CA4-4F53-4FEC-8B34-B60674F5A25D.jpg (63.2 KB, 28 views)
Thanks
Andy
1952 F1
adileo is offline   Reply With Quote
Old 09-23-2018, 04:19 PM   #2
JSeery
JSeery's Avatar
Default Re: 52 F1 solenoid
It would depend on the model of solenoid it is, but seems odd.
I have never seen this style before, but here it is!
Old 09-23-2018, 04:37 PM   #3
adileo
adileo's Avatar
Jerry
Hats off to you once again!
I guess it don’t matter but according to the pic and my pic it looks like mine is upside down
Also mine is 6 volt
Thanks
Andy
1952 F1
Old 09-23-2018, 05:26 PM   #4
Jersey Devil
Jersey Devil's Avatar
ANDY
Picture attached of my 52 6volt. Red wires go to voltage regulator and horn relay. Small wire to starter button. Heavy black to starter and from battery.
Hope this helps,
Tom
File Type: jpg AAABE1DB-0380-4E0A-8AA1-0B56725868BD.jpg (65.9 KB, 40 views)
Jersey Devil is offline   Reply With Quote
Old 09-23-2018, 06:02 PM   #5
adileo
adileo's Avatar
Hey Tom, hope all is well.
I have an odd ball setup. Jerry found answer.
Thanks
Andy
1952 F1
Old 09-23-2018, 06:11 PM   #6
51 MERC-CT
51 MERC-CT's Avatar
How does this translate to 6 volt positive ground systems?
Old 09-23-2018, 07:45 PM   #7
JSeery
JSeery's Avatar
The instruction sheet says 12v, so would assume negative ground. Think the point is this type of solenoid exist. I have no idea if there is a 6v version, but would guess there is as Andy stated his vehicle is 6v.
Old 09-23-2018, 08:16 PM   #8
tubman
tubman's Avatar
When I built my engine test stand, I set it up for 12 volt negative ground and bought a appropriate solenoid from NAPA.
About 6 months later, I had a '51 Mercury engine I wanted to test. I put my Optima battery in the battery box and switched a few wires around, and tried the engine; it stared and ran great. A couple of days later, I realized that I had not changed the solenoid. Since it worked with no problem, I just shrugged my shoulders and kept on doin' what I was doin'.
That was about three years ago, and I have had several engines on the stand (both 6 and 12 volt) since, and the solenoid has never missed a beat.
Old 09-23-2018, 08:26 PM   #9
michael a
michael a's Avatar
What you have is a constant on solenoid you can ground either of the smaller post and by the same token you can light up either the smaller post to get the solenoid to work and what it is is not a regular starter solenoid but a solenoid that they use 4 heavy amp usage instead of burning up a switch you run the big wires through the solenoid they were great for starters and where they really shine is on things like fire and tow trucks where there is a ton of Lights and you run it off the solenoid and let your switch just energize it
Sent from my SM-J700T using Tapatalk
michael a is offline   Reply With Quote
Old 09-23-2018, 08:45 PM   #10
Tinker
Tinker's Avatar
solenoid grounds through the base to cowl. On a 4 pole solenoid one of the small post goes to the starter button the other is a momentary straight 6v to the coil. I haven't seen a metal version like you have. Pretty neat.
The red wire going from the mount bolt to a ground isn't really needed, but I bet it works well. Take the solenoid off and clean a little paint off the the cowl and add a washer to assure a little more surface contact. Then you can remove the wire (if your bat 2 body is solid).
Old 09-23-2018, 08:54 PM   #11
JSeery
JSeery's Avatar
Tinker, that is how most four terminal solenoids work, this is a different type that can be switched between ground triggered and power triggered. It requires the jumper to ground to work.
Old 09-23-2018, 09:02 PM   #12
Tinker
Tinker's Avatar
Noted. Sorry. Never seen this, and picked the wrong red wire.
What's the reason or benefit?
Old 09-23-2018, 09:06 PM   #13
Tinker
Tinker's Avatar
Okay I think I get it??
Old 09-23-2018, 09:09 PM   #14
JSeery
JSeery's Avatar
I have never seen this type before either, interesting setup.
Old 09-23-2018, 09:09 PM   #15
Bob C
Tinker, there are 5 different 4 terminal solenoids that are all wire differently internally.
Bob
Old 09-23-2018, 09:15 PM   #16
Tinker
Tinker's Avatar
Okay Bob, this helps. Thank you.
Designed for a system that has 24 or more volts to run equipment (like a firetruck) but not run the solenoid down. Or what i'm reading. maybe...
This looks to be a circuit 9. If I'm reading to correctly. Maybe 6.
Interesting.
