Old 02-22-2011, 10:38 AM   #1
Tom in SW VA
Tom in SW VA's Avatar
Default What can be done about a Bachelor Lean?
Many have posed this question before, but I am still very interested in a solution. Short of getting a real heavy person to sit on the right side, what is the cause and solution for a car leaning to the left side, a.k.a, ... a Bachelor Lean? I feel confident that the problem lies in the rear spring area. Any suggestions??? Is replacing the spring the only solution?
Thanking you in advance.................
Tom in SW VA
Tom in SW VA is offline   Reply With Quote
Old 02-22-2011, 10:59 AM   #2
deuce lover
deuce lover's Avatar
Default Re: What can be done about a Bachelor Lean?
Try loosening the spring clamp on the drivers side and tightening the clamp on pass side.
Old 02-22-2011, 11:03 AM   #3
Gary in La.
Gary in La.'s Avatar
I'm not sure changing springs will be your answer. I installed NOS front and rear springs on my '46 convertable thinking this would cure the minor offset but it did not. Maybe Henry built them this way. Several other V-8's around here also have the left lean be it ever so slight.
Gary in La. is offline   Reply With Quote
Old 02-22-2011, 11:15 AM   #4
1931 flamingo
1931 flamingo's Avatar
Is the spring center bolt broken? Is the bolt head inserted into the frame crossmember?
Paul in CT
Old 02-22-2011, 11:18 AM   #5
billwill
Tom in SW VA
Frame is bent.
billwill is offline   Reply With Quote
Old 02-22-2011, 11:28 AM   #6
flatheadernie
Thats why we turn left on the hi speed ovals, faster that way. other than wedges on front left and rear springs enjoy the look!! LOL ernie n tx
flatheadernie is offline   Reply With Quote
Old 02-22-2011, 11:28 AM   #7
Lawson Cox
Lawson Cox's Avatar
Lose some weight? lol
Old 02-22-2011, 12:22 PM   #8
jerry grayson
Deuce Lover has the answer. loosen the spring to crossmember u bolts on one side and tighten the other side, front and rear.
jerry grayson is offline   Reply With Quote
Old 02-22-2011, 01:09 PM   #9
Coupe35
On my 35, I removed the rear spring and rotated it to where the left side was now on the right side. Did not help at all. Maybe I need to do the front spring also.
Coupe35 is offline   Reply With Quote
Old 02-22-2011, 01:18 PM   #10
Mart
Mart's Avatar
I made a sheetmetal shim that fitted between the spring and the crossmember and folded one side double. I fitted that, and tightened the u-bolts carefully to correct a persistant lean. I seem to remember fitting one front and rear.
Mart.
Old 02-22-2011, 01:32 PM   #11
51 MERC-CT
51 MERC-CT's Avatar
As above;
Could add a wedge between the spring and crossmember of the proper angle just like we used on stock cars in the 50's. (that's where the term "adding a little wedge" came from that is now used in stock cars)
Old 02-22-2011, 02:39 PM   #12
Mike51Merc
Mike51Merc's Avatar
For what it's worth, I read that some cars are engineered with a little "batchelor lean" because we drive on the right and most of our roads are crowned (highest) at the center.
Mike51Merc is offline   Reply With Quote
Old 02-23-2011, 12:30 AM   #13
Adam/Mill Valley CA
Adam/Mill Valley CA's Avatar
Are you sure the rear spring is exactly centered on the crossmember? It was a little off center on my '36 pickup; loosened the U-bolts, moved the spring sideways to center it and it corrected the lean.
Adam
1936 pickup, stock, black
1965 Mustang coupe 289/4bbl, black/red
1971 Alfa Romeo GTV 1750 coupe, dark red/tan
1970 911E 2.2 litre dark blue/black
1968 BMW R50/2 US, black (m'cycle)
1967 Triumph TR6R , sea foam/cream (m'cycle)
2022 Royal Enfield Interceptor 650 red (m'cycle)
1974 Honda CB750 red (m'cycle)
2000 Kawasaki W650 blue/silver (m'cycle)
Adam/Mill Valley CA is offline   Reply With Quote
Old 02-23-2011, 03:06 AM   #14
Roadster62
Roadster62's Avatar
Rubenesque girlfriend.
Roadster62 is offline   Reply With Quote
Old 02-23-2011, 08:10 AM   #15
gerrald meacham
the shims that are posted will work , just play with them
gerrald meacham is offline   Reply With Quote
Old 02-23-2011, 08:50 AM   #16
4dFord/SC
4dFord/SC's Avatar
Any suggestions for a Mechanic's Lean?
4dFord/SC is offline   Reply With Quote
Old 02-23-2011, 09:38 AM   #17
Kube
Super Moderator
Kube's Avatar
While I appreciate all the advise you've been given, With all due respect, I have to say, DO THE REPAIR CORRECTLY. Adding shims, etc. is what we referred to (pre PC) as 'riggin it".
If nothing is broken (or worn very badly) in the spring assembly (shackles, etc) than it's simple - you need new springs.
These cars were NOT designed to lean one way or the other. They were designed to sit level. Any quick check of a dimensional drawing, crash manual, etc. will quickly allow that reality.
Old 02-23-2011, 01:28 PM   #18
Lawson Cox
Lawson Cox's Avatar
Is that to be read, Mechanic's "lien"? LOL
Old 02-23-2011, 01:42 PM   #19
JM 35 Sedan
JM 35 Sedan's Avatar
You can't fool a lawyer when it comes to legal lingo
John
Old 02-23-2011, 01:57 PM   #20
Seth Swoboda
Seth Swoboda's Avatar
I would first check to make sure the center bolt in the leaf spring is not broken or just not centered up on the cross member. I have seen this problem before with my dads 47 Tudor and we centered up the leaf spring with the cross member to fix it.
