Old 07-26-2018, 09:06 AM   #1
Bob Bidonde
Bob Bidonde's Avatar
Default Most Unreliable Model "A" Parts
What are the most unreliable parts of a Model "A"?
Bob Bidonde
Old 07-26-2018, 09:22 AM   #2
Anteek29
Anteek29's Avatar
Default Re: Most Unreliable Model "A" Parts
The nut behind the wheel?
Alan
1929 Special Coupe
1941 Pick-Up
1955 Victoria
Anteek29 is offline   Reply With Quote
Old 07-26-2018, 09:29 AM   #3
Benson
Any part inside of a "Rick Pack" !!
Old 07-26-2018, 09:33 AM   #4
Charlie Stephens
The condenser due to the amount of heat its is exposed to. Then there are the current low quality ones that are out there, another story. I always have an extra under the seat.
Charlie Stephens
Old 07-26-2018, 09:37 AM   #5
katy
katy's Avatar
Gasoline quantity.
Old 07-26-2018, 09:43 AM   #6
Jeff/Illinois
Jeff/Illinois's Avatar
Inner tubes, the bad ones NOT sold by Bratton's.
Old 07-26-2018, 09:58 AM   #7
P.S.
Those rubber brake and clutch pedal pads that are designed to come off when you slightly brush against them.
P.S. is offline   Reply With Quote
Old 07-26-2018, 10:20 AM   #8
Cape Codder
Cape Codder's Avatar
BOB - Can you P.M. or email me on another subject.
My e-mail is [email protected]
Cape Codder is offline   Reply With Quote
Old 07-26-2018, 12:13 PM   #9
Flathead
Flathead's Avatar
Probably very few when the car was new. Most problems now involve repro parts, we are fortunate to have reproduced parts available but there are some clunkers. Then there are the parts designed to "improve" the A, often with mixed results. YMMV
Flathead is offline   Reply With Quote
Old 07-26-2018, 02:34 PM   #10
Chris Haynes
Chris Haynes's Avatar
Anything from Vintique.
1921 Runabout
1930 Tudor
Early 1930 AA
Old 07-26-2018, 04:39 PM   #11
dpson
dpson's Avatar
The elcheepo repro brake light switches, both the early and late types.
For the later 30-31 type pay the extra to get the good one, you won't regret it.
dpson is offline   Reply With Quote
Old 07-26-2018, 05:16 PM   #12
Keith True
Keith True's Avatar
My grandfather sold them new,he said the first thing to go was the gas guage float.sometimes they were resting on the bottom when the cars came in.He said the shocks were next,or maybe the roof would leak.Those were kind of neck and neck for timing.A year and a half or so.He said the fenders would crack in a couple of years.The roads were not paved,and they would rack the cars terribly.Until about 1939 it was about 20 miles to a good road.With good float material now the floats won't sink,good seals and oils the shocks won't leak out,modern seam sealers and the edges of the roofs won't open up,and with smoother roads the fenders aren't so prone to cracking.
Keith True is online now   Reply With Quote
Old 07-26-2018, 07:13 PM   #13
MikeK
MikeK's Avatar
If you are talking original parts and design, I would think the short list would be found within anything that did not move from the VE27's to continued 28 and later "A" production and those mechanical and body/frame parts that saw major change during the transition to the '32 "B" design and specs.
Some items: 1/2" shaft Abel starter drive, block, flywheel housing, and banjo castings without adequate reinforcement ribs, float hinge direction on A Zeniths, wood framed bodies, . . .
MikeK is offline   Reply With Quote
Old 07-26-2018, 09:44 PM   #14
daren007
Aftermarket Amp meter.
daren007 is offline   Reply With Quote
Old 07-27-2018, 12:32 AM   #15
Y-Blockhead
Y-Blockhead's Avatar
Now wait a minute. Their Fordor door handle pads are pretty good...
Old 07-27-2018, 02:28 AM   #16
dumb person
dumb person's Avatar
You all missed the obvious, the gas is ok, the batteries are all throw away after 6 months.
<Link> This is how we roll<Link>
"I'm Convinced that no one really reads posts anymore; they just fabricate what they think the post says then ramble on about red herrings."--Bob
Outcasts rules of old cars
#1 Fun is imperative, mainstream is overrated
#2 If they think it is impossible, prove them wrong
#3 If the science says it impossible you are not being creative enough.
#4 No shame in recreating something you never had
#5 If it were not for the law & physics you would be unstoppable
dumb person is offline   Reply With Quote
Old 07-27-2018, 07:51 AM   #17
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Them STUPID gas valves, that don't shut off, entirely & you dump a quarter tank of gas, on the FLOOR & your Sweet Wife makes you sell your stupid car, CHEAP!
Bill Ticked
"THE ASSISTANT GURU OF STUFF"
Old 07-27-2018, 07:55 AM   #18
gweilbaker
gweilbaker's Avatar
Tank mounted steering column support.
gweilbaker is offline   Reply With Quote
Old 07-27-2018, 08:12 AM   #19
Bob Bidonde
Most unreliable OEM parts / designs in my opinion:
Fan;
Service brakes;
Water pump;
Babbitt bearings;
Starter Bendix;
Generator cutout;
Ignition condenser;
Non-adjustable valves;
Exhaust manifold;
Distributor lower plate wire;
Cooling system;
Engine mount system;
Single wire electrical system.
Bob Bidonde
Old 07-27-2018, 09:43 AM   #20
F.M.
Hand Operated windshield wiper !!..
F.M. is offline   Reply With Quote
