Old 07-22-2018, 08:29 PM   #1
GerryAllen
Default Does anyone use Dello 15 - 40 wt Oil
When I bought my car the seller was using Chevron, Dello 15 - 40 and suggested I continue on using it. I spoke with a chap the other day and mentioned I was about to change my oil and was using Dello 15 -40.
He seemed to be a bit negative about using it as he said it was detergent free. Is this the case, I would appreciate the "seasoned and not so seasoned" Model A types opinions.
Gerry Allen Birch Bay WA
GerryAllen is offline   Reply With Quote
Old 07-22-2018, 08:58 PM   #2
J Franklin
J Franklin's Avatar
Default Re: Does anyone use Dello 15 - 40 wt Oil
Look on the jug, I doubt it is a non-detergent oil.
Old 07-22-2018, 08:59 PM   #3
M2M
M2M's Avatar
He is wrong. See:
https://www.chevronlubricants.com/en...le-15w-40.html
Nothing wrong with that oil but if you believe high levels of ZDDP help prevent metal on metal wear then I suggest "Mobil-1 15w-50" or "Mobil-1 20w-50 V-Twin" which have very high levels of ZDDP. See:
https://www.walmart.com/ip/Mobil-1-1...5-qts/20713647
https://www.walmart.com/ip/Mobil-1-2...1-qt/16767830?
https://mobiloil.com/~/media/amer/us...pecs-guide.pdf
Or you can just add this to "normal" cheap oil:
https://rislone.com/product/3x-conce...inc-treatment/
M2M is offline   Reply With Quote
Old 07-22-2018, 09:27 PM   #4
CarlG
CarlG's Avatar
I've been using Shell's equivalent: Rotella 15-40. Seems to work just fine for me.
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 07-22-2018, 09:42 PM   #5
J Franklin
J Franklin's Avatar
Or there we went!
Old 07-22-2018, 10:07 PM   #6
eagle
eagle's Avatar
You mean Delo. It will be just fine, or buy whatever is on sale.
Old 07-22-2018, 10:21 PM   #7
GerryAllen
My apology, you are correct Delo. Being new to forums, I never thought of the search function.
For those that I have offended by bringing up the subject yet again, what can I say
Old 07-23-2018, 12:37 AM   #8
J Franklin
J Franklin's Avatar
No offense. How are you going to learn if you don't try?
Old 07-24-2018, 12:07 PM   #9
Jim Brierley
15-40 oils are meant for diesels and not advised for gas engines. I use 20-50, whatever kind is on sale.
Old 07-24-2018, 02:43 PM   #10
J Franklin
J Franklin's Avatar
Diesel engines work under much higher compression and loads. I have never seen a recommendation not to use 15-40 multi-viscosity oil in a gas engine.
Old 07-24-2018, 12:47 PM   #11
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Most ANY oil you name, is used by SOMEBODY???SOMEWHERE???? Hope this helps.
Bill W.
"THE ASSISTANT GURU OF STUFF"
Old 07-24-2018, 03:16 PM   #12
Growley bear
DELO: Diesel Engine Lube Only
This was over 50yrs. ago when engine oil was in cans and we opened it up with a push in opener/pour spout.
What about Chevron Purple Triton? I used that when it was available.
Growley bear is offline   Reply With Quote
Old 07-24-2018, 03:48 PM   #13
J Franklin
J Franklin's Avatar
Talking Re: Does anyone use Dello 15 - 40 wt Oil
DELO- Desired Excellent Lube Overall
Old 07-24-2018, 03:41 PM   #14
Gary WA
Gary WA's Avatar
Been using Delo 400 for years in A's
www.whidbeymodelaclub.com
Old 07-24-2018, 03:52 PM   #15
M2M
M2M's Avatar
Which one? The 30wt or 40wt?
Old 07-24-2018, 03:54 PM   #16
Y-Blockhead
Y-Blockhead's Avatar
I use Delo 400 15w-40
Old 07-25-2018, 07:11 AM   #17
Growley bear
DELO used to mean Diesel Engine Lube Only. I was instructed under the penalty of losing my job to never use it in a gasoline engine. We used Chevron Purple Triton in gasoline engines; when engine oil was in round cans and was opened with a push in opener/pour spout.
Of course things have changed since then with lubrication oil.
Old 07-25-2018, 11:11 AM   #18
Jim Brierley
Ask 10 Model A guys anything and you will get 12 answers!
Old 07-26-2018, 05:04 AM   #19
Growley bear
I know a couple of guys who use it in their Model A engines with good results. They like it.
Old 07-26-2018, 09:46 AM   #20
gustafson
Some highly experienced users here state clearly that any oil at all will work just fine, including detergent and non-detergent.
non-detergent is cheaper
gustafson is offline   Reply With Quote
