Old 07-15-2018, 11:23 AM   #1
IndyA
Default Level in Gas Tank????
I lost the cork on my gas gauge (with all most a full tank of fuel)...how far down do I have to drop the gas level before I can remove the dash board gauge ?? Many thanks.. Indy A
IndyA is offline   Reply With Quote
Old 07-15-2018, 11:31 AM   #2
WHN
Default Re: Level in Gas Tank????
My personal view would be to drive it until it is almost empty. Than drain the rest. I also would let the tank vent for a while when empty.
I don’t like to work around open gas.
Old 07-15-2018, 12:14 PM   #3
kimeccles
kimeccles's Avatar
Regular cork will deteriorate again, so you should replace with newer special float end that can handle the gas/ethanol that we often are stuck with these days.
Also, agree to empty tank as that allows you to set the bend in the float arm to 0 empty line and full estimate before sealing.
kimeccles is offline   Reply With Quote
Old 07-15-2018, 12:15 PM   #4
Y-Blockhead
Y-Blockhead's Avatar
To answer the OP's question, a little lower than ¾ tank.
Old 07-15-2018, 12:36 PM   #5
redmodelt
redmodelt's Avatar
Anywhere below the opening that does not slosh out when you get in and out.
DO NOT FORGET TO DISCONNECT THE BATTERY!
Old 07-15-2018, 01:16 PM   #6
WHN
Murphy’s Law. Have you heard of it?
IF SOMETHING WHERE TO HAPPEN. How do you explain it to your insurance company.
“I was working on an open, over half full gas tank”? Who would of thought it might be a problem?
Old 07-15-2018, 01:33 PM   #7
Big hammer
A empty tank is more dangerous than a full tank, gasoline as a liquid doesn’t burn, the vapor is what burns! I watched a welder weld a gas filler neck, he would not weld until the tank was completely full and with a water wetted towels around where he was welding. Another story was a man in a junkyard struck a match near an open gas tank and bloom went the tank.
At half a tank I have no gas showing nor splashing in my gauge. I will suggest you try and find and remove the missing float, as it may sink and cover the gas outlet like with my late 31 tank. I need to remove a missing float because it is causing flow issues :-(
Another don’t do this at home, me as a dumb kid poured gas onto a wet leaves that wouldn’t burn, the gas vapors lit up following the liquid stream to the can! Iwas lucky and didn’t get burned.
get a bigger hammer tap done
Old 07-15-2018, 01:47 PM   #8
WHN
Your right, a half a tank of gas won’t give off any vapor? Really?
I still say to empty it and let it breath. Yes there is still vapor, but at least there should be no gas to add more vapor.
I would plan for what could happen and hope that everything goes all right.
Also. Anyone who would think about welding a full tank of gas, would not be work for me. Sounds like a war story.
Old 07-15-2018, 02:08 PM   #9
1931 flamingo
1931 flamingo's Avatar
DISCONNECT the battery before you start to do anything ! ! !
Is it the cork float or the cork on the gauge sight glass??
Paul in CT
Old 07-15-2018, 02:31 PM   #10
IndyA
Thanks to all of you - this Wed site is such a good thing!!!!.... No, it is not the cork gasket ... it is the float. And I know from the Snyder's catalogue that Neoprene is better than Cork... so the new one will be the proper one.
Old 07-15-2018, 02:37 PM   #11
redmodelt
redmodelt's Avatar
Every time you choke an A, filter or not there are fumes and gas dripping. Every time you fill the tank there are fumes it's not a sealed system. What difference would it make having under 1/2, 1/4 or empty, there are still fumes involved. Coming up with a very highly unlikely worse case in changing the float, hog wash.
Old 07-15-2018, 03:37 PM   #12
WHN
There are a lot of “Hog Wash” things that end up happening.
Giving someone advice to be as safe as possible, I do not think is Hog Wash.
Giving bad advice, or don’t worry about it advice, I would consider Hog Wash.
You know there is always the chance of something happening. We are only talking about a gallon of gas at most. With tank empty you can properly adjust float at empty, you can drain out any small dirt particles, and no matter what you think, if something were to go wrong, you have done everything to avoid it.
Advice is free. Take it or leave it. That’s what this forum is for. Enjoy.
Old 07-15-2018, 04:20 PM   #13
Synchro909
Synchro909's Avatar
I'd empty the tank but not for the reasons given above. I set the gauge to read empty when the float is sitting on he bottom of the tank. It needs to be empty to do that.
One of my As has been running around for years with a float made from the cork from a champagne bottle. Once I skewered it on the wire, I dipped the whole thing in tank sealer figuring if that stuff keeps fuel in, it should keep it out. Simple and effective! I did similar for a friend whose float had sprung a leak and sank in his 1926 Fiat. That's still going too.
Even at my age, I still like to look at a young, attractive woman but I can't really remember why.
Old 07-15-2018, 05:35 PM   #14
Tom Wesenberg
Tom Wesenberg's Avatar
#4 is right, but I'd empty the tank to make it easier to fish out the cork.
I had to do the same thing on my 28 when I first bought it.
Old 07-15-2018, 09:32 PM   #15
Slowplane
Slowplane's Avatar
When I emptied my tank for gauge work, I measured the gas going back in and made a "calibrated" dipstick for a back up.
______________
Nothing Short of Right is Right
Slowplane is offline   Reply With Quote
Old 07-16-2018, 09:16 AM   #16
Lona
Lona's Avatar
Or, if you are lazy, use a calibrated dip stick and measure your fuel level through the gas tank opening. I remember reading a thread some time age on the forum about how to make these sticks and how to calibrate them. I have one but its made for a Model T tank.
Glen
'31 Model A Deluxe Roadster
'35 Packard Convertible Sedan
'88 Pontiac Fiero GT
'36 Auburn Boattail Speedster replica
Lona is offline   Reply With Quote
Old 07-16-2018, 09:51 AM   #17
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
A screwtop Gallon can, 1/2 full of GAS, has the potential power of probably 27 sticks of DYNAMITE!!!!
Bill Confetti
"THE ASSISTANT GURU OF STUFF"
Old 07-21-2018, 06:12 AM   #18
Growley bear
The first item of business is to disconnect the battery.
Growley bear is offline   Reply With Quote
Old 07-21-2018, 06:35 AM   #19
larry harding
an older guy who ran a harley dealership many years ago told me the secret to welding a gass tank. don't freak out!!! find some way to have a flow of air into the tank and back out. this can be done different ways, on smaller tanks such as motorcycle tanks i hook an air hose to the outlet and leave the filler open. i have even heard of hooking the exhaust of a running auto or other eingine to the tank. the idea is this.... with a still tank a spark or flame of any kind can go into the tank and boom! as long as air is traveling out the flame can't go in. i have repaired several tanks over the years using this method with no problems. i saw a video on youtube nce where a guy ligted up the rear of a car and brazed a penny over the hole with gass in the tank with gass in the tank. i'm not that nuts
larry harding is offline   Reply With Quote
