Old 07-12-2018, 12:53 PM   #8
DHZIEMAN
Default Re: Gas tank leaking
Originally Posted by johnbuckley View Post
Friend has left hand drive 1930 Tudor. Fuel is leaking from the left side of the tank. I assume the leak is from the steering column bracket.. Two questions for the Ford Barners
a) Is there any simple effective remedy other than removing tank?
b) How do you remove the tank from a 1930 Tudor ?
When it comes to fuel leaks in a Model A, the only solution for safety is to fix it right! And that requires removing the tank, and taking it to a radiator shop or some place similar and getting the tank rust cleaned out, and have a pro review if the tank is repairable. Once that is established, ya gotta do what ya gotta do to be safe. Gasoline is dangerous stuff.
Here locally, there is a radiator repair shop in Springfield, Mo that will take Model A gas tanks and repair them and coat the inside to stop the rusting. Have not had to do it yet, but if I do, that will be the avenue I take on fixing a fuel tank leak.
DHZIEMAN is offline   Reply With Quote
