Old 07-04-2018, 05:12 PM   #1
daren007
Default Model B distributor
My B engine with A distributor does not like advance at idle. A little is ok but more and she runs lousy. She is timed properly at TDC. while driving 1/3 advance seems to be the sweet spot for overall driving. If I install a B distributor I am told the timing should be now at 19 degrees before the mechanical advance takes over. This seems excessive. I would think it will affect my idle plus would I get a kickback on starting?
daren007 is offline   Reply With Quote
Old 07-04-2018, 05:21 PM   #2
ursus
Default Re: Model B distributor
It was evidently not excessive as many B-distributors have been installed in Model-A engines over the years. I have never had to crank mine by hand but have been assured that kickback should not be a problem provided one held the crank correctly, and Ford supplied a crank with the Model-B for both timing and starting.
Old 07-04-2018, 07:42 PM   #3
coatings03
I have a model B distributor on my A engine. Best thing I ever did, idle in consistent no issues with going uphill .
Jim m
coatings03 is offline   Reply With Quote
Old 07-04-2018, 10:58 PM   #4
Tom Wesenberg
Tom Wesenberg's Avatar
B engine with an A distributor, but what timing cover do you have?
Remember, a B cover is advanced when the pin drops into the dimple.
Old 07-05-2018, 01:04 PM   #5
Charlie Stephens
To illustrate Tom's post. The picture is a Model B timing cover. The timing pin is located in a tapped hole at the top of an oval boss. The Model A timing cover had a tapped hole in the center of a circular boss. A very few timing covers were made for the Model A as replacement parts with the tapped hole at the bottom of the oval boss.
Charlie Stephens
Old 07-05-2018, 05:47 PM   #6
daren007
I have an A front cover but would use a timing indicator. As I read the B is timed 18 degrees BTDC opposed to the A's TDC. This would mean the B is firing before TDC if so I would expect a kickback on starting.
Old 07-06-2018, 12:45 AM   #7
Tom Wesenberg
18 degrees won't kick back on the stock engine. I've even started mine with about 30 degrees advance when I forgot to retard the spark lever.
Old 07-06-2018, 07:57 AM   #8
daren007
How about with a "Touring cam".
Old 07-06-2018, 02:29 PM   #9
Railcarmover
Doesnt matter if its a touring cam,B distributor has the correct advance curve.Total advance is about 24 degrees,perfect for an A ,especially with a high compression head.Stock B points are getting scarce but Renners Corner retrofits them with modern points..drill through the lube port(its usually blocked by the bushing) and drill the cam screw so you can lube the upper shaft.And throw your spark control lever away...
Railcarmover is offline   Reply With Quote
Old 07-06-2018, 03:22 PM   #10
quickchange
quickchange's Avatar
We can supply new sets of B points if anyone requires them , Derek in a cold freezing NZ back from the hot Reno meet ,
quickchange is offline   Reply With Quote
Old 07-06-2018, 03:36 PM   #11
daren007
No high compression head.
Old 07-06-2018, 03:44 PM   #12
ursus
Regarding the oil port that is blocked by the bushing: that is what I have done in the past but was recently told that Ford had started installing oil impregnated bushings of the Oilite type during the Model B period. These are made of porous bronze that allow for oil to pass through to the bearing surface from the reservoir in the oiler port. Supposedly, you only need to drill a hole for access if you have installed non-porous bushings.
I wonder if anybody can cite a Ford reference to this bit of trivia?
Old 07-07-2018, 10:16 AM   #13
Growley bear
I could find no mention of an oilite bushing in the Ford service bulletins '32-'37. The "B" distributor on my Model A had an oilite bushing installed when I rebuilt it. To my knowledge it had never been apart except for minor adjustments. It had no oil hole. Unfortunatly I ha to install the newer bushing and drill it for lubrication. It has worked well for many years now.
Growley bear is offline   Reply With Quote
Old 07-07-2018, 12:19 PM   #14
Railcarmover
The key is finding one with good shafts,the upper and lower get galled from lack of lubrication.All model A engines can benefit from mechanical advance,detonation is one of the main causes of bearing failure,the hammer effect of detonation is increased with higher compression
Old 07-07-2018, 10:49 PM   #15
boo
when i rebuilt my B dist a couple yrs ago i put in new weights some one made that was supposed to change the advance to run better, anyone else use these weights??
boo is offline   Reply With Quote
Old 07-14-2019, 02:23 PM   #16
vonheine
I just bought a Model B distributor. I am planning to experiment with it in two different ways. 1) I am going to run it on s stock engine with the static timing set at 3 to 5 degrees BTDC. 2) When my second engine is built, with a 5:5:1 head, I will static time to TDC for less total advance. The stock engine will tolerate more total advance than the HC head. What I want to know is, what exactly is a high speed distributor cap for a Model B? I saw one on EBay and I had interest, because I find the quality of diamond shaped distributor caps to be horrible. However, it appeared to have no notch for the Model B timing indicator, or the advance window if used on a Model A. How does that work? It was a Nioff FF-71. I have taken a “modern distributor cap “ for a Model A and simply added a second index notch at 90 degrees to the Model A index notch. Now, I can use this cap on a Model B distributor. The advance window is still required for the Model B to clear the timing reference tab. Any inputs on this?
vonheine is offline   Reply With Quote
Old 07-14-2019, 03:31 PM   #17
Bob C
I looked in an old Niehoff catalog I have and that cap on Ebay in not an FF-71.
Bob
Bob C is online now   Reply With Quote
Old 07-14-2019, 07:30 PM   #18
vonheine
The Niohoff FF-71 that was on EBay is sold, gone. It was advertised that it fit a Ford Model B. There is a chart on this forum that confirms that number as a High Speed Model B cap. The cross reference was to an Ampco F-928. There are currently dozens of Nihoff caps on EBay, but those are not what I am talking about. I have the photograph on my phone. I am trying to figure out how to post it.
Old 07-14-2019, 07:42 PM   #19
Bob C
This is the one that was on Ebay, the box is marked right but the cap is
not an FF71. https://www.ebay.com/itm/Niehoff-FF-...p2047675.l2557
Old 07-14-2019, 08:17 PM   #20
vonheine
Bob, Thank You, that explains it! So, that is not an FF-71 cap. It’s just an FF-71 box. I actually bid on it when it was active. Now, I am glad I didn’t get it. It’s not the correct cap. That answers a lot of my questions. Does anyone have photos of a real FF-71? (A genuine high speed distributor cap for a Ford Model B)
